Software Archive
Read-only legacy content
17060 Discussions
Are R200 resolution limits surmountable?
Elizabeth_K_
Do R200's resolutions & frame rate limits (@60FPS depth at 480x360, color can be 320x240 or 640x480;
@30FPS depth at 480x360, color can be 320x240, 640x480, 1280x720, or 1920x1080) reflect a hardware limitation? Or is it possible that with future driver / firmware updates we'll be able to get higher resolution at 60 fps on the color cameras, while still outputting depth at the same or better resolutions & frame rates?
Xusheng_L_Intel
It was mainly restricted by the USB 3.0 bandwidth.
Gregory_B_1
The SDK supports:
4 * 1920 * 1080 * 30 = 249 megabytes
The SDK DOESN’T support:
4 * 1280 * 720 * 60 = 221 megabytes
This doesn’t make sense. Why is support for 720p at 60 FPS not an option?
Elizabeth_K_
Thanks, David! Gregory, those are my thoughts, as well:
720p at 60fps, which is not supported, has a lower bit rate than 1080p at 30fps, which IS supported.
Is the low limit on the 60 fps resolution enforced for some other reason, besides USB 3.0 bandwidth?
Xusheng_L_Intel
I think it is a good feature request and I will talk with my colleague. Thanks!
