Software Archive
Read-only legacy content
17060 Discussions
Array visulizer activex control problem
Intel_C_Intel
I have upgraded my visual fortran 6.5 to 6.6. I no longer able to use the
two array viewer activex controls (avis2d.ocx and avisgrid.ocx) in visual basic. I can place the control on a form and access the properties. But I
can't run or compile the vb code. When I try to run or make executable,
the vb6.exe will terminate with the following error:
The instruction at 0x0fac1075 reference to memory at "0x00000000". The memory could not be "read".
I am using windows 2000 sp2, visual basic enterprise 6.0 sp5.
Is this an isolated case? Is there any fixes available?
I have no problem to use the controls before the upgrade with the same version of vb and windows 2000 sp1.
Haifang Li
Assistant Professor of Radiology
Department of Radiology
SUNY at Stony Brook
Stony Brook, NY 11794
(631)444-2160
[email protected]
Report this problem to [email protected] and our Array Visualizer expert will respond. It doesn't sound familiar to me.
Please note that this forum is really intended as user-to-user support, not an alternative to contacting Compaq at [email protected]
Steve
Intel_C_Intel
Does any body use the avis2d.ocx and avisgrid.ocx with windows 2000 sp2?
