Software Archive
Read-only legacy content
Autocomplete Hint Error
Ricky_N_
In the XDK editor, it can pop up the options of autocompletion but it can't show the hint on the left.
PaulF_IntelCorp
That is an extension of the standard Brackets hint system that is designed to provide hints for IoT projects that are using mraa and upm. Unfortunately, it appears to be "bleeding thru" to other file and projects type. You can safely ignore it. I will report this as a bug in our hinting extension.
Ricky_N_
thanks
