Software Archive
Read-only legacy content
17060 Discussions
BIOS compatibility and upgrade question
admin5
Dell computer with Intel mother board. Latest Dell BIOS update installed. However, Dell BIOS is very limited. Found an Intel update for the mother board "Intel Corporation CA810E" that matches.
Used a hex editor to change the manufacurer from 86A to 10A in all files.
Question is: can I install this BIOS update and what are the chances of success. Also if I try and fail will the Dell BIOS update reinstall in Recovery Mode if need be.
Steve Easton
Microsoft MVP FrontPage
95isalive
This site is best viewed............
.......................with a computer
Intel_Software_Netw1
Thisquestion would need to be addressedby the Intel Desktop Boards support team; we recommend that you contact them directly at crmotherboard@mailbox.intel.com. However, they might need to refer you back to Dell* for the final word on compatibility, since this relates to an OEM version of an Intel Desktop Board and these motherboards may be customized to the OEM's specifications. Good luck!
Lexi S.
IntelSoftware NetworkSupport
http://www.intel.com/software
Contact us
Intel is a registered trademark of Intel Corporation or its subsidiaries in the United States and other countries.
*Other names and brands may be claimed as the property of others.
Message Edited by intel.software.network.support on 12-07-2005 04:26 PM
admin5
Thank you. forwarded as recommended
