Software Archive
Read-only legacy content
17060 Discussions
BUG - Intel XDK or C2
Flemming_P_
Hi hope someone can help with this
https://www.scirra.com/forum/viewtopic.php?f=146&t=127580&p=901896#p901896
Since im running out of idears - Would be so greatfull if someone could fix this issue
Cheers
Flemming
Swati_S_Intel1
Looks like you are using Legacy build option. Try using Cordova build options, Legacy build is going to be deprecated soon.
Swati
Flemming_P_
No... I use the cordava build.. And the crosswalk for the android version That plays the audio fine Tanks Flemming
Swati_S_Intel1
What format is the audio after you convert in C2?
Flemming_P_
IT is imported from wav and convertet as M4a as you ser in the post at C2 I forllow the guide in hos to export in C2 So it is therefore I seak helt here ;-)
Flemming_P_
I could mail you the files i use for compile cordava xdk
Swati_S_Intel1
Please zip the project folder and send it.
Swati
Flemming_P_
Ive just sent you (pm) the zipped file
Flemming_P_
HI  @SWATI S. (Intel)
have you had time to see whats wrong with my project ?
Cheers
Flemming
Swati_S_Intel1
Hi Flemming,
I tried your app you sent me. It looks like it is using Web Audio when you are running on the device. The audio is generally supported in webview but not reliable. You should be using Cordova for audio. If there is a way in C2 to force your app to use Cordova you should do that, otherwise you have to write js code to implement audio using Cordova plugin. There are examples available in sample apps.
Swati
Flemming_P_
OKAY ... Thanks
Just dont quite understand ... In C2 its exported as Cordova project
and in XDK build its a Cordova build ?
Cheers
Flemming_P_
Hi again
I still dont have any audio on my C2 > Cordova > xdk build
Is this not the right way
