I'm having an issue with the back button on the headers in the Intel XDK environment. I have my header set up with class="button" and it works fine except for I don't have the back button icon (chevron). Now if I change it to class="backButton" I get the back button icon (chevron) but the back button doesn't work very well. What happens is it goes back for a brief second then jumps forward to the page you were just on minus the header. It might just be something simple I am overlooking but not sure...
Below is a sample of my header code:
Working:
<header class="wrapping-col wrap-element uib_w_11 with-back" data-uib="app_framework/header" data-ver="2" id="contactsheader">
<h1>Contacts</h1><a href="#homepage" class="button" id="contactsButton"></a>
</header>
Not working:
<h1>Contacts</h1><a href="#homepage" class="backButton" id="contactsButton"></a>
</header>
- Tags:
- HTML5
- Intel® XDK
I am assuming that you upgraded to XDK V 2170.
You should use button backbutton instead of just button.
I tried and it worked.
<header class="wrapping-col wrap-element uib_w_1" data-uib="app_framework/header" data-ver="2" id="af-header-0">
<h1></h1>
</header>
<header class="wrapping-col wrap-element uib_w_2 with-back" data-uib="app_framework/header" data-ver="2" id="af-header-1"><a class="button backButton">Back</a>
<h1>SECOND</h1>
</header>
Or you can include back button through UI also. Please see the screenshot.
Yes I have upgraded to version 2170. I did that earlier since I was browsing the forums and found that might fix the issue which it did not.
I have also tried using class="button backButton" which was generated when I used the UI to create the header initially and that's when I found the problem. Changing that to class="button" seemed to work fine but did not have an icon or anything, just the word 'Back' if I put it in there, to indicate that a back button was present and it works fine. It seems to be whenever I try to add in the chevron icon to the back button that it doesn't seem to work.
