Software Archive
Read-only legacy content
17060 Discussions
Backlight Control using 82852/82855 chipset
novice28
How can we access the chipset's backlight control or is there a way to access it? I am currently using intel chipset 82852/82855 GM graphics adapter with a digital flat panel (TFT) and i'm running on windows XP embedded. I've tried a couple of approches in trying to control the backlight. IOCTL's for brightness control does not respond also i've tried to use Display Tuner wherein it uses DDC/CI protocol so that i might be able to use this protocol but it doesn't work.
Sorry if this might be a dumb question, actually i'm just a newbee... i hope someone can answer this.
I really need your help guys...
Thanks a lot...
