Software Archive
Read-only legacy content
Beacon
khin_sin_c_
Hi All,
 I have an app built in cordova, which i plan to provide a beacon solution. I wonder is the xdk ready to support the beacon solution? if yes, any beacon vendor or sdk i could refer to?
thanks
Chris_P_Intel
You mean iBeacon?
There is a third party iBeacon Cordova plugin: https://github.com/petermetz/cordova-plugin-ibeacon
You should be able to use it with the XDK with no problem.  I haven't worked with that plugin myself, nor iBeacon, so cannot advise you as to its ease or difficulty.
Hope this helps,
Chris
khin_sin_c_
Hi All,
found article about type of beacon technologies in the market:
https://developer.mbed.org/blog/entry/BLE-Beacons-URIBeacon-AltBeacons-iBeacon/
look like if using the cross platform development for marketing message purposes, UriBeacon is better?
http://www.gpsbusinessnews.com/Google-s-UriBeacon-More-Disruptive-than-iBeacon_a5306.html
thanks
khin_sin_c_
Hi Chris,
i try to monitor an ibeacon using the plugin with id: com.unarin.cordova.beacon.
When i try to do below in my code:
var delegate = new cordova.plugins.locationManager.Delegate();
there is always an error of "Uncaught TypeError: Cannot read property 'locationManager' of undefined" show in the log. May i know how could i make a refer to locationManager on the cordova plugin?
thanks
Chan KS
PaulF_IntelCorp
This looks to me like you do not have the plugin included as part of your app. Are you trying to do this from the Emulate tab? Third-party plugins won't work from there. See these doc pages:
