Software Archive
Read-only legacy content
17060 Discussions
Bilded application not working
furio_f_
L'applicazione deguggata sia in emilazione, che attraverso la connessione con un cellulare funziona, quando faccio la build e scarico l'apk sul cellulare va in errore usando l'ajax in essa contenuta. posso allegARE IL CODICE SIA DELL'HTML CHE DEL JAVASCRIPT CHE CONTIENE L'AJAX CHE VA A LEGGERE UN DB SU UN MIO SERVER
The application is in deguggata emilazione, through a connection with a mobile work, when I do the build and unloading the apk on your phone goes in error using the ajax contained therein. Can I attach CODE IS THAT OF THE HTML JAVASCRIPT THAT CONTAINS AJAX GOING TO READ A DB ON A MY SERVER
Dale_S_Intel
Have you tried debugging from the server side?   I.e. what do the server logs tell you about what's going on?
Dale
