Software Archive
Read-only legacy content
Binary File Compress
emrey
I need to read/write big data on the disk while my simulation continues. In order to make the size smaller on the disk I write the data as binary. However, the size of this data can be further decreased considerably by an external compressor . My question is, can I read\write in compressed binary format directly from Fortran?
Emre
gaston-hillar
Valued Contributor I
emrey,
Check the following thread that includes sample code for the problem you mention with Intel Fortran. It will definitely help you.
https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/276634
Hope it helps.
gaston-hillar
emrey,
I forgot to mention. The thread I mention in my previous response provides sample code to read ZIP files.
However, you can use a similar approach to read other compressed files.
