Software Archive
Read-only legacy content
17060 Discussions
Booting a Non-Linux OS
Reto_A_
I want to boot a non-linux OS on the Xeon Phi. Is there any documentation on that?
From the MPSS User Guide:
"The second part of the boot argument indicates to boot a Linux* image. It may also be set to elf to indicate booting a standard ELF format file. Documenting non-Linux* boot is beyond the scope of this document."
Is it possible to boot an elf-x86_64 (no unsupported vector instructions used) or does the elf need to be an elf-k1om? What is the entry point of the elf and can it be used to bootstrap the card OS?
There are two further questions that arise:
- How can the host be informed that the system is ready?
- How can the coprocessor OS write to the serial console (which arrives at /dev/ttyMICx on the host) ?
It is basically which SBOX registers do I have to set to which values?
Thanks for any replies on the questions.
Evan_P_Intel
Serial output requires a "POST card," a small circuit board with two 7-segment displays (for the two-character boot progress code) and the UART in question. The board is connected to the Xeon Phi with an I2C cable that resembles one of those CD-audio cables used in computer optical drives about a decade ago. So, you'd need a POST card and a Xeon Phi with the appropriate connector soldered down.... On the engineering team, the former have always been in short supply and the latter were unavailable, so we'd hand-solder the missing connectors.
In any case, because the UART is on the far side of an I2C bus, you'd need a rather thick driver stack to access it, more than would be desirable for early boot messages, and indeed MPSS's Linux kernel is not capable of using that UART for early_printk. Honestly, I suggest you print to an in-memory ring buffer (see the host mic.ko's code for reading the Linux dmesg buffer across PCIe) or emulate a serial port with a pair of such rings (see the card's michvc.ko code and its companion bits in the host's mic.ko).
TaylorIoTKidd
I don't know of any specific Intel information but there have been other threads on this topic. See http://software.intel.com/en-us/forums/topic/489529.
Taylor
Reto_A_
OK, I managed to boot an elf-64. How can I get serial output from the card to the host when booting a elf-64?
The documentation says:
Intel® Xeon Phi™ coprocessor hardware supports a serial console using the serial port device on the SBOX I2C bus.
Evan_P_Intel
Reto_A_
Thanks Evan for clearing up the misleading information in the documentation.
rhn
If the system has been successfully booted, post code will be FF (ASCII encoded in SBOX address 0x242c). There's a check the host driver makes against SCRATCH2 register bit 0, but that value seems to be controlled by the boot loader.
If there's some better way, I'm interested myself.
Reto_A_
if you boot the ELF way writing a 0x1 to SCRATCH2 will tell the host that its booted successfully. When booting the Linux way, there needs to be a SCIF based handshake.
