Software Archive
Read-only legacy content
17060 Discussions
Build Error and syntax error.
Sudeep_V_
I'm developing an app for iOS. So far I built 7 versions successfully but when I try to build 8th version, I'm getting the below error.
Syntax error in /D/Water Vapour/Box Sync/Construct 2/Freelance/Project-1/Intel/intelxdk.config.additions.xml:This page contains the following errors:error on line 8 at column 57: Opening and ending tag mismatch: plugin line 0 and widget Below is a rendering of the page up to the first error.
Earlier, I didn't had any problem with build.
The code is
<intelxdk:plugin intelxdk:name="cc.fovea.plugins.inapppurchase" intelxdk:value="cc.fovea.plugins.inapppurchase" />
<intelxdk:plugin intelxdk:name="com.mcm.plugins.androidinappbilling" intelxdk:value="https://github.com/maxmoore14/AndroidInAppBilling.git" />
<intelxdk:plugin intelxdk:name="https://github.com/cranberrygame/cordova-plugin-payment-iap" intelxdk:value="https://github.com/cranberrygame/cordova-plugin-payment-iap" />
<intelxdk:plugin intelxdk:name="https://github.com/cranberrygame/cordova-plugin-facebook" intelxdk:value="https://github.com/cranberrygame/cordova-plugin-facebook" >
<intelxdk:param intelxdk:name='APP_ID' intelxdk:value='1064516516912627' />
<intelxdk:param intelxdk:name='APP_NAME' intelxdk:value='Keep Me In! - Test1' />
<intelxdk:plugin intelxdk:name="org.apache.cordova.inappbrowser" intelxdk:value="org.apache.cordova.inappbrowser" />
<intelxdk:plugin intelxdk:name="org.apache.cordova.statusbar" intelxdk:value="org.apache.cordova.statusbar" />
Please help.
Elroy_A_Intel
Are you still experiencing this issue?
John_H_Intel2
From what I can see, all your iOS build are succeeding for the account you are using here in the forums. Are you using another account in the XDK?
