Software Archive
Read-only legacy content
17060 Discussions
Build Error
Ranjeet_V_
 I'm getting error when build my android app using cordova 5.4.1
 Error: Plugin Google Play Services for Android failed to install.
 Error: Plugin Android Support v4 failed to install.
 Kindly reply asap
PaulF_IntelCorp
Looks like you have two competing plugins, I believe the issue is they are trying to bring in competing library files. Hard to diagnose completely with just the summary log. Attach the complete detailed build log as a TXT file using the "Attach Files to Post" button below the forum edit window so we can look at more detail.
Also, try building with CLI 6.2.0.
marcio_a_
Jesus_R_
I have the same problem, some solution?
PaulF_IntelCorp
Probably, those plugins are known to compete and cause troubles.
