Software Archive
Read-only legacy content
17060 Discussions
Build Failed Admob Plugin
Tim_L_5
I'm trying to build my IOS app for days.... but no success.
My problem is:
The build failed.
An error occurred while building the application. Verify your build assets are correct and try again.
Build Log:
  • Building a Cordova 5.1.1 application.
  • The application name is "Days Game"
  • The package name is "com.Seache.Days"
  • Will use the provisioning profile for "adhoc"
  • Plugin "cordova-plugin-device" (1.1.0) installed.
  • Plugin "cordova-plugin-splashscreen" (2.1.0) installed.
  • Plugin "com.google.cordova.admob" (1.0.5) installed.
  • Plugin "org.apache.cordova.inappbrowser" (0.6.0) installed.
  • Targeting iOS version 7.0.
  • An unexpected error occured while attempting to build the application.
 I also tried other Admob plugins
The build failed.
You can view the detailed log of the iOS build here
Build Log:
  • Plugin "com.google.admobsdk" (6.12.2) installed.
  • Plugin "cordova-plugin-admob" (2.2.0) installed.
The build failed.
Build Log:
  • Plugin "cordova-plugin-extension" (1.2.3) installed.
  • Plugin "cordova-plugin-admobpro" (2.10.0) installed.
I don't know what to do.. please help me.
Here is the log for the Admob-Pro plugin: https://am-xdk2.s3.amazonaws.com/cust.5a9e3f67-fa58-4285-b4de-38848e1afb7c/app.04e76138-2205-422b-980d-66fbb6828ca2/iphone/build.201601021827.txt?AWSAccessKeyId=ASIAI7AEZ4ORSZVKNSNA&Expires=1451762383&x-amz-security-token=AQoDYXdzEBoa4AOnOPsSBSgUPognMKC%2B0rm9CvELCai%2BxQ338f%2FWRu38cxFfu1OQ25pGkv8wlnteJDCU1W37JaJogZWKtB6pWEfL7jsfWmwiGIdIpRuOnxNfKI...
Anusha_M_Intel1
If it builds successfully as an Android app, it might be a certificate or provisioning profile issue. Could you post your Intel XDK build log if any?
Amrita_C_Intel
I am unable to see the entire build log.The Cordova build has a link to the build log right under the the build failed message. Viewing that (focusing on the end of the log) will help you debug especially if you have included custom plugins. The transition from classic XDK to Cordova is very quick and straightforward - most of your code stays the same. Let me know if you need any guidance with that.
