Software Archive
Read-only legacy content
Build Failed?!
James_F_2
I followed this exactly to the letter, now its saying Build Failed?
https://software.intel.com/en-us/forums/intel-xdk/topic/607195
It worked earlier today idk what happened.  Earlier versions of Intel XDX didn't involve manually copying project filles into a seperate folder, it was just upload and compile and build.
James_F_2
This is really really annoying.  Earlier it worked perfectly. The way I'm uploading it has not changed, but now it says Build Failed.
Following the same exact steps it was perfectly fine.  What happened to how Intel XDX? Before it was select your project file, now it involves copying and pasting into another folder.
I'm mad because Intel XDX used to be, select folder and go from there.  And now following the tutorial steps work once and then not work consistently.
James_F_2
Sorry for ranting, i just remember Intel XDX allowing a developer to select a folder where the project files were stored, and complied from there.  Now it involves copying 2 files into a top level folder, and the rest into another folder. then copying and pasting image files into another folder.
So from one step to get project files to multiple steps.
