Software Archive
Read-only legacy content
Build Failed
Elite_W_
Hey guys I have some problem building my apps
here are the log
Calling plugman.fetch on plugin ".../cachedPlugins.94nHEq.tmp/cache.AGfKxG.pl/cordova-plugin-statusbar"
Copying plugin ".../cachedPlugins.94nHEq.tmp/cache.AGfKxG.pl/cordova-plugin-statusbar" => ".../cordova_project/plugins/cordova-plugin-statusbar"
Calling plugman.install on plugin ".../cordova_project/plugins/cordova-plugin-statusbar" for platform "android
Installing "cordova-plugin-statusbar" for android
Running command: .../cordova_project/platforms/android/cordova/version
Command finished with error code 0: .../cordova_project/platforms/android/cordova/version
Install start for "cordova-plugin-statusbar" on android.
Install complete for cordova-plugin-statusbar on android.
Checking for any plugins added to the project that have not been installed in android platform
No differences found between plugins added to project and installed in android platform. Continuing...
Generating config.xml from defaults for platform "android"
Wrote out Android application name to "LearnUpAsiaApp"
Wrote out Android package name to "learnup.asia.app"
This app does not have launcher icons defined
updated project successfully
Calling plugman.fetch on plugin ".../cachedPlugins.94nHEq.tmp/cache.OHxdrR.pl/cordova-plugin-device"
Copying plugin ".../cachedPlugins.94nHEq.tmp/cache.OHxdrR.pl/cordova-plugin-device" => ".../cordova_project/plugins/cordova-plugin-device"
Calling plugman.install on plugin ".../cordova_project/plugins/cordova-plugin-device" for platform "android
Installing "cordova-plugin-device" for android
Install start for "cordova-plugin-device" on android.
Install complete for cordova-plugin-device on android.
Calling plugman.fetch on plugin ".../cachedPlugins.94nHEq.tmp/cache.QMOYsH.pl/cordova-plugin-splashscreen"
Copying plugin ".../cachedPlugins.94nHEq.tmp/cache.QMOYsH.pl/cordova-plugin-splashscreen" => ".../cordova_project/plugins/cordova-plugin-splashscreen"
Calling plugman.install on plugin ".../cordova_project/plugins/cordova-plugin-splashscreen" for platform "android
Installing "cordova-plugin-splashscreen" for android
Install start for "cordova-plugin-splashscreen" on android.
Install complete for cordova-plugin-splashscreen on android.
Calling plugman.fetch on plugin ".../cachedPlugins.94nHEq.tmp/cache.3zpT2I.pl/cordova-plugin-whitelist"
Copying plugin ".../cachedPlugins.94nHEq.tmp/cache.3zpT2I.pl/cordova-plugin-whitelist" => ".../cordova_project/plugins/cordova-plugin-whitelist"
Calling plugman.install on plugin ".../cordova_project/plugins/cordova-plugin-whitelist" for platform "android
Installing "cordova-plugin-whitelist" for android
Install start for "cordova-plugin-whitelist" on android.
Install complete for cordova-plugin-whitelist on android.
               This plugin is only applicable for versions of cordova-android greater than 4.0. If you have a previous platform version, you do *not* need this plugin since the whitelist will be built in.
Calling plugman.fetch on plugin ".../cachedPlugins.94nHEq.tmp/cache.8ODEoV.pl/cordova-plugin-crosswalk-webview"
Copying plugin ".../cachedPlugins.94nHEq.tmp/cache.8ODEoV.pl/cordova-plugin-crosswalk-webview" => ".../cordova_project/plugins/cordova-plugin-crosswalk-webview"
Calling plugman.install on plugin ".../cordova_project/plugins/cordova-plugin-crosswalk-webview" for platform "android
Installing "cordova-plugin-crosswalk-webview" for android
Install start for "cordova-plugin-crosswalk-webview" on android.
Updating build files since android plugin contained <framework>
Install complete for cordova-plugin-crosswalk-webview on android.
Checking config.xml for saved platforms that haven't been added to the project
Checking config.xml for saved plugins that haven't been added to the project
************* Processing the main config.xml file (after_prepare)  *****************
App Directory = [.../cordova_project]
Will process and update the following config files:
    Config.xml = [.../cordova_project/config.xml]
Namespaces:
    prefix/uri ''/'http://www.w3.org/ns/widgets'
    prefix/uri 'intelxdk'/'http://xdk.intel.com/ns/v1'
Android Manifest Namespaces:
    prefix/uri 'android'/'http://schemas.android.com/apk/res/android'
Name of the app is [LearnUpAsiaApp]
Updating full app name to [LearnUpAsiaApp]
Processing preference android-minSdkVersion [14]
Processing preference android-targetSdkVersion [21]
Processing preference android-installLocation [auto]
Processing preference permissions
Updating the versionCode
Updating the versionName
Processing debuggable
Added [{http://schemas.android.com/apk/res/android}debuggable] with [false]
Processing config file values
Saving config.xml to [.../cordova_project/config.xml]
************* Completed processing the main config.xml file (after_prepare)  *****************
ANDROID_HOME=.../android-sdk/
JAVA_HOME=/usr/lib/jvm/java-8-oracle-amd64
Downloading http://services.gradle.org/distributions/gradle-2.2.1-all.zip
Unzipping /home/builduser/.gradle/wrapper/dists/gradle-2.2.1-all/2m8005s69iu8v0oiejfej094b/gradle-2.2.1-all.zip to /home/builduser/.gradle/wrapper/dists/gradle-2.2.1-all/2m8005s69iu8v0oiejfej094b
Set executable permissions for: /home/builduser/.gradle/wrapper/dists/gradle-2.2.1-all/2m8005s69iu8v0oiejfej094b/gradle-2.2.1/bin/gradle
Download https://repo1.maven.org/maven2/com/android/tools/build/gradle/1.5.0/gradle-1.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/build/gradle-core/1.5.0/gradle-core-1.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/build/builder/1.5.0/builder-1.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/lint/lint/24.5.0/lint-24.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/build/transform-api/1.5.0/transform-api-1.5.0.pom
Download https://repo1.maven.org/maven2/com/android/databinding/compilerCommon/1.0-rc5/compilerCommon-1.0-rc5.pom
Download https://repo1.maven.org/maven2/net/sf/proguard/proguard-gradle/5.2.1/proguard-gradle-5.2.1.pom
Download https://repo1.maven.org/maven2/net/sf/proguard/proguard-parent/5.2.1/proguard-parent-5.2.1.pom
Download https://repo1.maven.org/maven2/org/jacoco/org.jacoco.core/0.7.4.201502262128/org.jacoco.core-0.7.4.201502262128.pom
Download https://repo1.maven.org/maven2/org/jacoco/org.jacoco.build/0.7.4.201502262128/org.jacoco.build-0.7.4.201502262128.pom
Download https://repo1.maven.org/maven2/com/android/tools/build/builder-model/1.5.0/builder-model-1.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/build/builder-test-api/1.5.0/builder-test-api-1.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/sdklib/24.5.0/sdklib-24.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/sdk-common/24.5.0/sdk-common-24.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/common/24.5.0/common-24.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/build/manifest-merger/24.5.0/manifest-merger-24.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/ddms/ddmlib/24.5.0/ddmlib-24.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/jack/jack-api/0.9.0/jack-api-0.9.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/jill/jill-api/0.9.0/jill-api-0.9.0.pom
Download https://repo1.maven.org/maven2/com/squareup/javawriter/2.5.0/javawriter-2.5.0.pom
Download https://repo1.maven.org/maven2/org/sonatype/oss/oss-parent/7/oss-parent-7.pom
Download https://repo1.maven.org/maven2/org/bouncycastle/bcpkix-jdk15on/1.48/bcpkix-jdk15on-1.48.pom
Download https://repo1.maven.org/maven2/org/bouncycastle/bcprov-jdk15on/1.48/bcprov-jdk15on-1.48.pom
Download https://repo1.maven.org/maven2/org/ow2/asm/asm/5.0.3/asm-5.0.3.pom
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-parent/5.0.3/asm-parent-5.0.3.pom
Download https://repo1.maven.org/maven2/org/ow2/ow2/1.3/ow2-1.3.pom
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-tree/5.0.3/asm-tree-5.0.3.pom
Download https://repo1.maven.org/maven2/org/antlr/antlr-runtime/3.5.2/antlr-runtime-3.5.2.pom
Download https://repo1.maven.org/maven2/org/antlr/antlr-master/3.5.2/antlr-master-3.5.2.pom
Download https://repo1.maven.org/maven2/org/sonatype/oss/oss-parent/9/oss-parent-9.pom
Download https://repo1.maven.org/maven2/org/antlr/antlr/3.5.2/antlr-3.5.2.pom
Download https://repo1.maven.org/maven2/com/android/tools/lint/lint-checks/24.5.0/lint-checks-24.5.0.pom
Download https://repo1.maven.org/maven2/org/eclipse/jdt/core/compiler/ecj/4.4.2/ecj-4.4.2.pom
Download https://repo1.maven.org/maven2/com/android/tools/annotations/24.5.0/annotations-24.5.0.pom
Download https://repo1.maven.org/maven2/com/google/guava/guava/17.0/guava-17.0.pom
Download https://repo1.maven.org/maven2/com/google/guava/guava-parent/17.0/guava-parent-17.0.pom
Download https://repo1.maven.org/maven2/com/android/databinding/baseLibrary/1.0-rc5/baseLibrary-1.0-rc5.pom
Download https://repo1.maven.org/maven2/org/apache/commons/commons-lang3/3.3.2/commons-lang3-3.3.2.pom
Download https://repo1.maven.org/maven2/org/apache/commons/commons-parent/33/commons-parent-33.pom
Download https://repo1.maven.org/maven2/org/apache/apache/13/apache-13.pom
Download https://repo1.maven.org/maven2/com/tunnelvisionlabs/antlr4/4.5/antlr4-4.5.pom
Download https://repo1.maven.org/maven2/com/tunnelvisionlabs/antlr4-master/4.5/antlr4-master-4.5.pom
Download https://repo1.maven.org/maven2/commons-io/commons-io/2.4/commons-io-2.4.pom
Download https://repo1.maven.org/maven2/org/apache/commons/commons-parent/25/commons-parent-25.pom
Download https://repo1.maven.org/maven2/org/apache/apache/9/apache-9.pom
Download https://repo1.maven.org/maven2/com/googlecode/juniversalchardet/juniversalchardet/1.0.3/juniversalchardet-1.0.3.pom
Download https://repo1.maven.org/maven2/net/sf/proguard/proguard-base/5.2.1/proguard-base-5.2.1.pom
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-debug-all/5.0.1/asm-debug-all-5.0.1.pom
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-parent/5.0.1/asm-parent-5.0.1.pom
Download https://repo1.maven.org/maven2/com/android/tools/layoutlib/layoutlib-api/24.5.0/layoutlib-api-24.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/dvlib/24.5.0/dvlib-24.5.0.pom
Download https://repo1.maven.org/maven2/com/google/code/gson/gson/2.2.4/gson-2.2.4.pom
Download https://repo1.maven.org/maven2/org/apache/commons/commons-compress/1.8.1/commons-compress-1.8.1.pom
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpclient/4.1.1/httpclient-4.1.1.pom
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpcomponents-client/4.1.1/httpcomponents-client-4.1.1.pom
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/project/4.1.1/project-4.1.1.pom
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpmime/4.1/httpmime-4.1.pom
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpcomponents-client/4.1/httpcomponents-client-4.1.pom
Download https://repo1.maven.org/maven2/net/sf/kxml/kxml2/2.3.0/kxml2-2.3.0.pom
Download https://repo1.maven.org/maven2/org/antlr/ST4/4.0.8/ST4-4.0.8.pom
Download https://repo1.maven.org/maven2/com/android/tools/lint/lint-api/24.5.0/lint-api-24.5.0.pom
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-analysis/5.0.3/asm-analysis-5.0.3.pom
Download https://repo1.maven.org/maven2/com/tunnelvisionlabs/antlr4-runtime/4.5/antlr4-runtime-4.5.pom
Download https://repo1.maven.org/maven2/com/tunnelvisionlabs/antlr4-annotations/4.5/antlr4-annotations-4.5.pom
Download https://repo1.maven.org/maven2/com/intellij/annotations/12.0/annotations-12.0.pom
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpcore/4.1/httpcore-4.1.pom
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpcomponents-core/4.1/httpcomponents-core-4.1.pom
Download https://repo1.maven.org/maven2/commons-logging/commons-logging/1.1.1/commons-logging-1.1.1.pom
Download https://repo1.maven.org/maven2/org/apache/commons/commons-parent/5/commons-parent-5.pom
Download https://repo1.maven.org/maven2/org/apache/apache/4/apache-4.pom
Download https://repo1.maven.org/maven2/commons-codec/commons-codec/1.4/commons-codec-1.4.pom
Download https://repo1.maven.org/maven2/org/apache/commons/commons-parent/11/commons-parent-11.pom
Download https://repo1.maven.org/maven2/com/android/tools/external/lombok/lombok-ast/0.2.3/lombok-ast-0.2.3.pom
Download https://repo1.maven.org/maven2/org/abego/treelayout/org.abego.treelayout.core/1.0.1/org.abego.treelayout.core-1.0.1.pom
Download https://repo1.maven.org/maven2/com/android/tools/build/gradle/1.5.0/gradle-1.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/build/gradle-core/1.5.0/gradle-core-1.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/build/builder/1.5.0/builder-1.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/lint/lint/24.5.0/lint-24.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/build/transform-api/1.5.0/transform-api-1.5.0.jar
Download https://repo1.maven.org/maven2/com/android/databinding/compilerCommon/1.0-rc5/compilerCommon-1.0-rc5.jar
Download https://repo1.maven.org/maven2/net/sf/proguard/proguard-gradle/5.2.1/proguard-gradle-5.2.1.jar
Download https://repo1.maven.org/maven2/org/jacoco/org.jacoco.core/0.7.4.201502262128/org.jacoco.core-0.7.4.201502262128.jar
Download https://repo1.maven.org/maven2/com/android/tools/build/builder-model/1.5.0/builder-model-1.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/build/builder-test-api/1.5.0/builder-test-api-1.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/sdklib/24.5.0/sdklib-24.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/sdk-common/24.5.0/sdk-common-24.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/common/24.5.0/common-24.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/build/manifest-merger/24.5.0/manifest-merger-24.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/ddms/ddmlib/24.5.0/ddmlib-24.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/jack/jack-api/0.9.0/jack-api-0.9.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/jill/jill-api/0.9.0/jill-api-0.9.0.jar
Download https://repo1.maven.org/maven2/com/squareup/javawriter/2.5.0/javawriter-2.5.0.jar
Download https://repo1.maven.org/maven2/org/bouncycastle/bcpkix-jdk15on/1.48/bcpkix-jdk15on-1.48.jar
Download https://repo1.maven.org/maven2/org/bouncycastle/bcprov-jdk15on/1.48/bcprov-jdk15on-1.48.jar
Download https://repo1.maven.org/maven2/org/ow2/asm/asm/5.0.3/asm-5.0.3.jar
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-tree/5.0.3/asm-tree-5.0.3.jar
Download https://repo1.maven.org/maven2/org/antlr/antlr-runtime/3.5.2/antlr-runtime-3.5.2.jar
Download https://repo1.maven.org/maven2/org/antlr/antlr/3.5.2/antlr-3.5.2.jar
Download https://repo1.maven.org/maven2/com/android/tools/lint/lint-checks/24.5.0/lint-checks-24.5.0.jar
Download https://repo1.maven.org/maven2/org/eclipse/jdt/core/compiler/ecj/4.4.2/ecj-4.4.2.jar
Download https://repo1.maven.org/maven2/com/android/tools/annotations/24.5.0/annotations-24.5.0.jar
Download https://repo1.maven.org/maven2/com/google/guava/guava/17.0/guava-17.0.jar
Download https://repo1.maven.org/maven2/com/android/databinding/baseLibrary/1.0-rc5/baseLibrary-1.0-rc5.jar
Download https://repo1.maven.org/maven2/org/apache/commons/commons-lang3/3.3.2/commons-lang3-3.3.2.jar
Download https://repo1.maven.org/maven2/com/tunnelvisionlabs/antlr4/4.5/antlr4-4.5.jar
Download https://repo1.maven.org/maven2/commons-io/commons-io/2.4/commons-io-2.4.jar
Download https://repo1.maven.org/maven2/com/googlecode/juniversalchardet/juniversalchardet/1.0.3/juniversalchardet-1.0.3.jar
Download https://repo1.maven.org/maven2/net/sf/proguard/proguard-base/5.2.1/proguard-base-5.2.1.jar
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-debug-all/5.0.1/asm-debug-all-5.0.1.jar
Download https://repo1.maven.org/maven2/com/android/tools/layoutlib/layoutlib-api/24.5.0/layoutlib-api-24.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/dvlib/24.5.0/dvlib-24.5.0.jar
Download https://repo1.maven.org/maven2/com/google/code/gson/gson/2.2.4/gson-2.2.4.jar
Download https://repo1.maven.org/maven2/org/apache/commons/commons-compress/1.8.1/commons-compress-1.8.1.jar
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpclient/4.1.1/httpclient-4.1.1.jar
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpmime/4.1/httpmime-4.1.jar
Download https://repo1.maven.org/maven2/net/sf/kxml/kxml2/2.3.0/kxml2-2.3.0.jar
Download https://repo1.maven.org/maven2/org/antlr/ST4/4.0.8/ST4-4.0.8.jar
Download https://repo1.maven.org/maven2/com/android/tools/lint/lint-api/24.5.0/lint-api-24.5.0.jar
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-analysis/5.0.3/asm-analysis-5.0.3.jar
Download https://repo1.maven.org/maven2/com/tunnelvisionlabs/antlr4-runtime/4.5/antlr4-runtime-4.5.jar
Download https://repo1.maven.org/maven2/com/tunnelvisionlabs/antlr4-annotations/4.5/antlr4-annotations-4.5.jar
Download https://repo1.maven.org/maven2/com/intellij/annotations/12.0/annotations-12.0.jar
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpcore/4.1/httpcore-4.1.jar
Download https://repo1.maven.org/maven2/commons-logging/commons-logging/1.1.1/commons-logging-1.1.1.jar
Download https://repo1.maven.org/maven2/commons-codec/commons-codec/1.4/commons-codec-1.4.jar
Download https://repo1.maven.org/maven2/com/android/tools/external/lombok/lombok-ast/0.2.3/lombok-ast-0.2.3.jar
Download https://repo1.maven.org/maven2/org/abego/treelayout/org.abego.treelayout.core/1.0.1/org.abego.treelayout.core-1.0.1.jar
null
org.xwalk:xwalk_core_library:19+
Download https://download.01.org/crosswalk/releases/crosswalk/android/maven2/org/xwalk/xwalk_core_library/19.49.514.5/xwalk_core_library-19.49.514.5.pom
Download https://download.01.org/crosswalk/releases/crosswalk/android/maven2/org/xwalk/xwalk_core_library/19.49.514.5/xwalk_core_library-19.49.514.5.aar
:preBuild UP-TO-DATE
:preArmv7ReleaseBuild UP-TO-DATE
:checkArmv7ReleaseManifest
:preX86ReleaseBuild UP-TO-DATE
:CordovaLib:preBuild UP-TO-DATE
:CordovaLib:preReleaseBuild UP-TO-DATE
:CordovaLib:compileReleaseNdk UP-TO-DATE
:CordovaLib:compileLint
:CordovaLib:copyReleaseLint UP-TO-DATE
:CordovaLib:mergeReleaseProguardFiles
:CordovaLib:packageReleaseRenderscript UP-TO-DATE
:CordovaLib:checkReleaseManifest
:CordovaLib:prepareReleaseDependencies
:CordovaLib:compileReleaseRenderscript
:CordovaLib:generateReleaseResValues
:CordovaLib:generateReleaseResources
:CordovaLib:packageReleaseResources
:CordovaLib:compileReleaseAidl
:CordovaLib:generateReleaseBuildConfig
:CordovaLib:generateReleaseAssets UP-TO-DATE
:CordovaLib:mergeReleaseAssets
:CordovaLib:processReleaseManifest
:CordovaLib:processReleaseResources
:CordovaLib:generateReleaseSources
:CordovaLib:compileReleaseJavaWithJavacNote: Some input files use or override a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
:CordovaLib:processReleaseJavaRes UP-TO-DATE
:CordovaLib:transformResourcesWithMergeJavaResForRelease
:CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease
:CordovaLib:mergeReleaseJniLibFolders
:CordovaLib:transformNative_libsWithMergeJniLibsForRelease
:CordovaLib:transformNative_libsWithSyncJniLibsForRelease
:CordovaLib:bundleRelease
:prepareAndroidCordovaLibUnspecifiedReleaseLibrary
:preArmv7DebugBuild UP-TO-DATE
:preX86DebugBuild UP-TO-DATE
:CordovaLib:preDebugBuild UP-TO-DATE
:CordovaLib:compileDebugNdk UP-TO-DATE
:CordovaLib:copyDebugLint UP-TO-DATE
:CordovaLib:mergeDebugProguardFiles
:CordovaLib:packageDebugRenderscript UP-TO-DATE
:CordovaLib:checkDebugManifest
:CordovaLib:prepareDebugDependencies
:CordovaLib:compileDebugRenderscript
:CordovaLib:generateDebugResValues
:CordovaLib:generateDebugResources
:CordovaLib:packageDebugResources
:CordovaLib:compileDebugAidl
:CordovaLib:generateDebugBuildConfig
:CordovaLib:generateDebugAssets UP-TO-DATE
:CordovaLib:mergeDebugAssets
:CordovaLib:processDebugManifest
:CordovaLib:processDebugResources
:CordovaLib:generateDebugSources
:CordovaLib:compileDebugJavaWithJavacNote: Some input files use or override a deprecated API.
:CordovaLib:processDebugJavaRes UP-TO-DATE
:CordovaLib:transformResourcesWithMergeJavaResForDebug
:CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
:CordovaLib:mergeDebugJniLibFolders
:CordovaLib:transformNative_libsWithMergeJniLibsForDebug
:CordovaLib:transformNative_libsWithSyncJniLibsForDebug
:CordovaLib:bundleDebug
:prepareComAndroidSupportSupportCompat2420Library
:prepareComAndroidSupportSupportCoreUi2420Library
:prepareComAndroidSupportSupportCoreUtils2420Library
:prepareComAndroidSupportSupportFragment2420Library
:prepareComAndroidSupportSupportMediaCompat2420Library
:prepareComAndroidSupportSupportV42420Library
:prepareOrgXwalkXwalk_core_library19495145Library
:prepareArmv7ReleaseDependencies
:compileArmv7ReleaseAidl
:compileArmv7ReleaseRenderscript
:generateArmv7ReleaseBuildConfig
:generateArmv7ReleaseAssets UP-TO-DATE
:mergeArmv7ReleaseAssets
:createXwalkCommandLineFileArmv7Release
:generateArmv7ReleaseResValues
:generateArmv7ReleaseResources
:mergeArmv7ReleaseResources
:processArmv7ReleaseManifest
:processArmv7ReleaseResources FAILED
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':processArmv7ReleaseResources'.
> com.android.ide.common.process.ProcessException: org.gradle.process.internal.ExecException: Process 'command '.../android-sdk/build-tools/21.1.2/aapt'' finished with non-zero exit value 1
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
Total time: 1 mins 31.378 secs
Error: Error code 1 for command: .../cordova_project/platforms/android/gradlew with args: cdvBuildRelease,-b,.../cordova_project/platforms/android/build.gradle,--no-daemon,-Pandroid.useDeprecatedNdk=true
Jerroyd_M_Intel
Hey Elite,
Discovered your problem: you have an "www/img/Logo.png" (case insensitive) file which is a reserved filename for Cordova. Rename it and your build will work.
Elite_W_
Helllo
Jerroyd_M_Intel
Hi Elite W.,
There isn't anything interesting or revealing in the log you posted, except for
* What went wrong:
I will send you a Private Message so I can recreate the issue with your project.
Elite_W_
Can anyone help me?
PaulF_IntelCorp
Elite -- I've pinged Jerroyd.
Jerroyd_M_Intel
Hey Elite,
odeta__peace
this was what i found, when i tried to build the xdk project for my android phone... please what do i do to correct this..i am using version XDK3400
PaulF_IntelCorp
Please see the release notes > https://software.intel.com/en-us/xdk/docs/release-notes-information-intel-xdk < you need to upgrade the copy of the XDK you are using.
