Software Archive
Read-only legacy content
17060 Discussions
Build Failing for Android Crosswalk
Nick_B_2
Hello Everyone,
I've installed the Intel App Security Cordova plugin, and it keeps failing when I try to build for Android Crosswalk with Cordova 5.1.1. All of the other plugins install fine, and I was able to build cleanly before I installed the app security plugin. Any help would be much appreciated.
This is all it shows for the build log:
An error occurred while building the application. Verify your build assets are correct and try again.
Build Log:
  • Building a Cordova 5.1.1 application.
  • The application name is "Your Church"
  • The package name is "www.bondappdev.yourchurch"
  • Preference android-signed set to false. Application will not be signed.
  • Plugin "com.bunkerpalace.cordova.YoutubeVideoPlayer" (1.0.1) installed.
  • Plugin "cordova-plugin-secure-storage" (2.1.0) installed.
  • Plugin "cordova-plugin-actionsheet" (2.2.0) installed.
  • Plugin "nl.x-services.plugins.backgroundaudio" (1.0.1) installed.
  • Plugin "cordova-plugin-x-socialsharing" (5.0.7) installed.
  • Plugin "org.apache.cordova.dialogs" (0.2.11) installed.
  • Plugin "org.apache.cordova.file" (1.3.2) installed.
  • Plugin "org.apache.cordova.media" (0.2.15) installed.
  • Plugin "com.telerik.plugins.nativepagetransitions" (0.5.5) installed.
  • Plugin "cordova-sqlite-storage" (0.7.13) installed.
  • Plugin "de.appplant.cordova.plugin.printer" (0.7.1) installed.
  • Plugin "cordova-plugin-inappbrowser" (1.1.0) installed.
  • Plugin "phonegap-plugin-push" (1.4.3) installed.
  • Plugin "cordova-plugin-device" (1.1.0) installed.
  • Plugin "de.appplant.cordova.common.registerusernotificationsettings" (1.0.1) installed.
  • Plugin "de.appplant.cordova.plugin.local-notification" (0.8.2) installed.
  • Plugin "cordova-plugin-splashscreen" (2.1.0) installed.
  • Error: Plugin APP Security API failed to install.
  • Plugin "cordova-plugin-whitelist" (1.1.0) installed.
  • Plugin "cordova-plugin-crosswalk-webview" (1.3.1) installed.
Elroy_A_Intel
Are you only seeing this issue with the Crosswalk for Android Build? Have you tried the Android build target?
Nick_B_2
Thanks for getting back to me, and for helping me with this issue. Yes I'm having issues with the Android for Crosswalk build. I haven't tried building it only for Android, but I need the crosswalk version to work for my app.
Nick_B_2
Even though I need it to build correctly with the Android for Crosswalk build I went ahead and built it for regular Android. It still failed with the same message. Any thoughts?
PaulF_IntelCorp
Confirm that you've got the most recent version of that plugin installed. There were some issues with older versions of that plugin. The most recent version is 1.4.0 -- you can uninstall it using the plugin manager and re-install it.
