Software Archive
Read-only legacy content
Build Failing with certain plugins
gabry_p_
Hello, I'm having some problem building with Crosswalk (11) an application, started as a new blank application with HTML5+Cordova.
The build fails when I include this plugin for push notifications.
I obtain the same with AeroGear and with PushWoosh. I checked the dependencies and I included all of them manually (even if they get automatically loaded by the plugin manager with the Early Access).
I tested both on the 2366 and on the Early Access, they keep giving me build failed cause of these plugins.
Maybe you can check the report on the server and give me more details.
PaulF_IntelCorp
@gabry -- do you have better luck if you use the new release (2496) and create a CLI 5.1.1 project?
Amrita_C_Intel
Thank you for pointing out. I have escalated your request. I will update you soon.
PaulF_IntelCorp
Amrita_C_Intel
Hello Gabry,
I included Pushwoosh plugin through git repo option which exist under third party plugin which is under plugin management. I am using XDK v 2496, CLI version 4.1.2  and built it for crosswalk. The build was successful for me. I would recommend you to upgrade the version of the XDK and try creating new project.
gabry_p_
Hi, I just tested with the new release and it seems working. Guess it is because of the new CLI 5.1.1.
Thanks again.
