Software Archive
Read-only legacy content
17060 Discussions
Build OTA download doesn't work
BerndB
Hello Intel-Team,
at the moment it is not possible to download builds OTA direct from the email sent from the appcenter.
After clicking on the link "click here to install your app OTA..." the following error message appears:
Are there any known issues? It did work 5 hours ago without any problem. Also older builds (ios) can't be downloaded anymore, While download from the Intel XDK seems to work as usual
Thanks for your great support
Cheers Bernd
PaulF_IntelCorp
Uncheck the "use a secure download link" and try it again. Not sure this is the problem, but I have a suspicion.
PaulF_IntelCorp
Nope, that does not work. We are working on the issue. This is likely related to the change in login that just happened.
PaulF_IntelCorp
It happened about 30 minutes ago.
PaulF_IntelCorp
Yes, iTunes install should work. We're trying to get the OTA to work, as well. There is a login issue that will not work for a while.
