Software Archive
Read-only legacy content
17060 Discussions
Build Problems
C_P_
I tried to build my app but after dissolving the ASCII problems Intel XDK (3522) shows new problems.
Uploading the project was fine but here are the fails (from Intel XDK log):
:compileArmv7ReleaseNdk UP-TO-DATE
:compileArmv7ReleaseSources
:transformClassesWithDexForArmv7Release
:mergeArmv7ReleaseJniLibFolders
:transformNative_libsWithMergeJniLibsForArmv7Release
:processArmv7ReleaseJavaRes UP-TO-DATE
:transformResourcesWithMergeJavaResForArmv7Release
:packageArmv7Release
:assembleArmv7Release
:checkX86ReleaseManifest
:prepareX86ReleaseDependencies
:compileX86ReleaseAidl
:compileX86ReleaseRenderscript
:generateX86ReleaseBuildConfig
:generateX86ReleaseAssets UP-TO-DATE
:mergeX86ReleaseAssets
Error: java.io.IOException: No space left on device
:mergeX86ReleaseAssets FAILED
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':mergeX86ReleaseAssets'.
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
Total time: 2 mins 41.833 secs
* What went wrong:
Failed to notify build listener.
* Try:
Error: Error code 1 for command: .../builds/build.2016-09-16.05-35-44.2rs7RE.tmp/cordova_project/platforms/android/gradlew with args: cdvBuildRelease,-b,.../builds/build.2016-09-16.05-35-44.2rs7RE.tmp/cordova_project/platforms/android/build.gradle,--no-daemon,-Pandroid.useDeprecatedNdk=true
What I have to change?
Please help!!
Jerroyd_M_Intel
Hi C P,
Try building your app again. It looks like the build server simply ran out of disk space.
C_P_
Yes, it worked after second try.
Thank you!
