Software Archive
Read-only legacy content
17060 Discussions
Build error using PushWoosh
Nick_F_2
New Contributor III
I have added PushWoosh to an app that previously compiled OK.
I've added a new provisioning profile and certificate created from PushWoosh (Auto), but I get the following error on build for iOS. Android builds OK.
Ld build/myappname.build/Release-iphoneos/myappname.build/Objects-normal/arm64/myappname normal arm64
    cd .../myappnameV9PUSH/platforms/ios
    export IPHONEOS_DEPLOYMENT_TARGET=8.0
    export PATH="/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin:/Applications/Xcode.app/Contents/Developer/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/local/git/bin:/Developer/android-sdk-macosx/tools:/usr/local/ant/bin"
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++ -arch arm64 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -L.../myappnameV9PUSH/platforms/ios/build/device -L.../myappnameV9PUSH/platforms/ios/myappname/Plugins/com.pushwoosh.plugins.pushwoosh -F.../myappnameV9PUSH/platforms/ios/build/device -filelist .../myappnameV9PUSH/platforms/ios/build/myappname.build/Release-iphoneos/myappname.build/Objects-normal/arm64/myappname.LinkFileList -dead_strip -weak_framework CoreFoundation -weak_framework UIKit -weak_framework AVFoundation -weak_framework CoreMedia -weak-lSystem -ObjC -fobjc-arc -fobjc-link-runtime -miphoneos-version-min=8.0 -framework AssetsLibrary .../myappnameV9PUSH/platforms/ios/build/device/libCordova.a -framework CoreGraphics -framework MobileCoreServices -weak_framework AudioToolbox -framework CoreLocation -weak_framework ImageIO -framework AVFoundation -liconv -framework CoreVideo -framework QuartzCore -framework CoreImage -weak_framework SystemConfiguration .../myappnameV9PUSH/platforms/ios/myappname/Plugins/com.pushwoosh.plugins.pushwoosh/Pushwoosh -framework Security -framework Storekit -lstdc++ -lz -Xlinker -dependency_info -Xlinker .../myappnameV9PUSH/platforms/ios/build/myappname.build/Release-iphoneos/myappname.build/Objects-normal/arm64/myappname_dependency_info.dat -o .../myappnameV9PUSH/platforms/ios/build/myappname.build/Release-iphoneos/myappname.build/Objects-normal/arm64/myappname
Ld build/myappname.build/Release-iphoneos/myappname.build/Objects-normal/armv7s/myappname normal armv7s
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++ -arch armv7s -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -L.../myappnameV9PUSH/platforms/ios/build/device -L.../myappnameV9PUSH/platforms/ios/myappname/Plugins/com.pushwoosh.plugins.pushwoosh -F.../myappnameV9PUSH/platforms/ios/build/device -filelist .../myappnameV9PUSH/platforms/ios/build/myappname.build/Release-iphoneos/myappname.build/Objects-normal/armv7s/myappname.LinkFileList -dead_strip -weak_framework CoreFoundation -weak_framework UIKit -weak_framework AVFoundation -weak_framework CoreMedia -weak-lSystem -ObjC -fobjc-arc -fobjc-link-runtime -miphoneos-version-min=8.0 -framework AssetsLibrary .../myappnameV9PUSH/platforms/ios/build/device/libCordova.a -framework CoreGraphics -framework MobileCoreServices -weak_framework AudioToolbox -framework CoreLocation -weak_framework ImageIO -framework AVFoundation -liconv -framework CoreVideo -framework QuartzCore -framework CoreImage -weak_framework SystemConfiguration .../myappnameV9PUSH/platforms/ios/myappname/Plugins/com.pushwoosh.plugins.pushwoosh/Pushwoosh -framework Security -framework Storekit -lstdc++ -lz -Xlinker -dependency_info -Xlinker .../myappnameV9PUSH/platforms/ios/build/myappname.build/Release-iphoneos/myappname.build/Objects-normal/armv7s/myappname_dependency_info.dat -o .../myappnameV9PUSH/platforms/ios/build/myappname.build/Release-iphoneos/myappname.build/Objects-normal/armv7s/myappname
ld: file is universal (4 slices) but does not contain a(n) armv7s slice: .../myappnameV9PUSH/platforms/ios/myappname/Plugins/com.pushwoosh.plugins.pushwoosh/Pushwoosh file '.../myappnameV9PUSH/platforms/ios/myappname/Plugins/com.pushwoosh.plugins.pushwoosh/Pushwoosh' for architecture armv7s
clang: error: linker command failed with exit code 1 (use -v to see invocation)
Ld build/myappname.build/Release-iphoneos/myappname.build/Objects-normal/armv7/myappname normal armv7
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang++ -arch armv7 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -L.../myappnameV9PUSH/platforms/ios/build/device -L.../myappnameV9PUSH/platforms/ios/myappname/Plugins/com.pushwoosh.plugins.pushwoosh -F.../myappnameV9PUSH/platforms/ios/build/device -filelist .../myappnameV9PUSH/platforms/ios/build/myappname.build/Release-iphoneos/myappname.build/Objects-normal/armv7/myappname.LinkFileList -dead_strip -weak_framework CoreFoundation -weak_framework UIKit -weak_framework AVFoundation -weak_framework CoreMedia -weak-lSystem -ObjC -fobjc-arc -fobjc-link-runtime -miphoneos-version-min=8.0 -framework AssetsLibrary .../myappnameV9PUSH/platforms/ios/build/device/libCordova.a -framework CoreGraphics -framework MobileCoreServices -weak_framework AudioToolbox -framework CoreLocation -weak_framework ImageIO -framework AVFoundation -liconv -framework CoreVideo -framework QuartzCore -framework CoreImage -weak_framework SystemConfiguration .../myappnameV9PUSH/platforms/ios/myappname/Plugins/com.pushwoosh.plugins.pushwoosh/Pushwoosh -framework Security -framework Storekit -lstdc++ -lz -Xlinker -dependency_info -Xlinker .../myappnameV9PUSH/platforms/ios/build/myappname.build/Release-iphoneos/myappname.build/Objects-normal/armv7/myappname_dependency_info.dat -o .../myappnameV9PUSH/platforms/ios/build/myappname.build/Release-iphoneos/myappname.build/Objects-normal/armv7/myappname
** BUILD FAILED **
Rakshith_K_Intel
The build server is now updated to xcode7, the armv7s build issue should be resolved
PaulF_IntelCorp
Nick, can you attach the entire build log, I think the key lines are further north in that file.
Nick_F_2
New Contributor III
Hi Paul
I have PM'd you with the log file.
PaulF_IntelCorp
Nick -- no PM with a log. For something like a build log, please just attach it directly to your forum post. Use the "Attach Media" button below the edit window when you are creating a new post. Paul
Nick_F_2
New Contributor III
Hi Paul
Not sure what happen there then
Log attached below.
PaulF_IntelCorp
I'm not seeing any useful information in that build log, :( This may be a case where Xcode 7 is required to build with this plugin. There are a few out there and our iOS build system has not yet been upgraded to use Xcode 7.
Nick_F_2
New Contributor III
Hi Paul
Thanks for the update.
Somewhat confused as I believe there are developers on this forum using PushWoosh in their projects, but I have been unable to pinpoint the cause of the error.
PaulF_IntelCorp
The confusion is probably due to the differences between the CLI 4 and CLI 5 build systems. We're seeing lots of situations where things that work well on CLI 4.1.2 don't work well on CLI 5.1.1, and vice versa.
Jim_G_
I ran into something similar with a third-party library.  I could be wrong, but I believe this is caused by incompatible build options between an underlying library associated with the plugin and the Intel XDK Build Service compile options.
In Xcode 6, Apple removed the armv7s architecture from the standard build settings.  Because of this, the armv7s options is excluded from the creation of the a library (.a) associated with the plugin - more likely to happen with newer or frequently updated libraries.  Because the Intel XDK Build Service includes the armv7s architecture option when compiling, an error is throw because the plugin library lacks support for it.
Here's an article discussing this condition:
https://www.cocoanetics.com/2014/10/xcode-6-drops-armv7s/
Solutions include getting the plugin/library developer to include armv7s in the compile/link options when building the underlying library. Or excluding armv7s from the Intel XDK build options (not sure how).
PaulF_IntelCorp
We're in the process of updating our iOS build systems so they use Xcode 7 rather than Xcode 6. I expect this to resolve most of these issues. Unfortunately, we are not allowed to publish a timeline as to when that change will happen. All I can say is that it is in process.
Idan_H_
Same problem !
** BUILD FAILED **
The following build commands failed:
	Ld build/Pushwoosh-Sample.build/Release-iphoneos/Pushwoosh-Sample.build/Objects-normal/armv7s/Pushwoosh-Sample normal armv7s
Aaron_C_1
Same problem! I have been trying to get PushWoosh working again for three days with no success. I even tried switching my code over to Urban Airship without much success. Any ETA on when this might be resolved?
PaulF_IntelCorp
We do not yet have an updated iOS build, that includes Xcode 7. In the meantime, your best bet is to use an older version of the plugin.
Rakshith_K_Intel
