Software Archive
Read-only legacy content
17060 Discussions
Build failed IOS and Cordova
Henk_M_
I'm trying to do a build for an IOS app with Cordova but keep getting a Build Failed.
I have no idea what causes this. The error log doesn't help a lot.
Could you please help me out?
Henk
** BUILD FAILED **
The following build commands failed:
        Check dependencies
(1 failure)
ERROR building one of the platforms: Error code 65 for command: xcodebuild with args: -xcconfig,.../EAOGV_IPHONE/platforms/ios/cordova/build-release.xcconfig,-project,EAOGV-IPHONE.xcodeproj,ARCHS=armv7 arm64,-target,EAOGV-IPHONE,-configuration,Release,-sdk,iphoneos,build,VALID_ARCHS=armv7 arm64,CONFIGURATION_BUILD_DIR=.../EAOGV_IPHONE/platforms/ios/build/device,SHARED_PRECOMPS_DIR=.../EAOGV_IPHONE/platforms/ios/build/sharedpch
You may not have the required environment or OS to build this project
Error: Error code 65 for command: xcodebuild with args: -xcconfig,.../EAOGV_IPHONE/platforms/ios/cordova/build-release.xcconfig,-project,EAOGV-IPHONE.xcodeproj,ARCHS=armv7 arm64,-target,EAOGV-IPHONE,-configuration,Release,-sdk,iphoneos,build,VALID_ARCHS=armv7 arm64,CONFIGURATION_BUILD_DIR=.../EAOGV_IPHONE/platforms/ios/build/device,SHARED_PRECOMPS_DIR=.../EAOGV_IPHONE/platforms/ios/build/sharedpch
Swati_S_Intel1
@Henk, There is a mismatch between your certificate and provisioning profile. Please follow this thread with a similar issue.
Follow the steps in this post : https://software.intel.com/en-us/forums/intel-xdk/topic/627945#comment-1870013
Amrita_C_Intel
You may need to uninstall the existing app on your device and then try building it again.
And clear the cache.
https://software.intel.com/en-us/xdk/blog/remove-xdk-local-data
Amrita_C_Intel
Replied through PM.
Swati_S_Intel1
Henk_M_
Dear Swati,
That was the problem.
Thanx a lot!!!!!
Henk
