Software Archive
Read-only legacy content
17060 Discussions
Build failed
Jure_C_
I have to which I made changes more then a year ago and now I have to update it. I have downloaded newest version of Intel XDK and because of that I also had to transform project to a newer version. Project has two build Android and iOS. I first started with Android one and when I try to build it, I get build failed. Here is the log:
550507
EDIT: If I build with CLI 5.1.1 it builds fine, but higher CLI versions aren't working.
Jure
PaulF_IntelCorp
Your app includes the long retired "intel.xdk.device" plugin and it looks like that is causing the build problems > https://software.intel.com/en-us/xdk/docs/intel-xdk-api-cordova-plugin-methods-properties-events#intel.xdk.device < I recommend you rewrite your code so that any dependencies on that plugin's APIs are changed to use the current and maintained core Cordova plugins. You can easily locate those old xdk APIs by searching for "intel.xdk.device" in your source code.
