Software Archive
Read-only legacy content
Build failed
Jeroen_V_
I have several projects in IntelXDK. I build them yesterday without any problems. But since this morning I cannot build anything. Not on iOS not android. I have tried several projects, but they all fail.
attached you find one of the loggings.
Jeroen
John_H_Intel2
Did you change anything? Add any plugins?
The error is 1 duplicate symbol for architecture arm64
Jeroen_V_
Well, I did not change much. No changes to the plugins.
The only thing I did was removing a script for logging (JSConsole). I removed this from the index.html.
I also tried another project where I only updated the project to the new IntelXDK. But this project also won't build.
John_H_Intel2
Took a look at your build, it appears the author of the local notification plug just updated the plugin.
You need to specify version 0.7.8 and it should build.
Jeroen_V_
Ok, that is unexpected.
Never thought about the possibility that the plugin would be updated externally.
Thanks for your fantastic help.
I can build now succesfully.
John_H_Intel2
All we do is provide a way for you to link to external plugins. You are at the whim of the developer if you dont specify a particular version :)
