Software Archive
Read-only legacy content
17060 Discussions
Build fails after switching project to Cordova 5.1.1
David_B_12
Build fails with following towards the end of the build log.  I switched to project to the new version 5.1.1.  Switching the project back to 4.1.2 produces a successful build. No idea what to do about it as the error message doesn't tell me WHAT is wrong, although this bit worries me:
You may not have the required environment or OS to build this project
Here is the rest:
:compileReleaseJavaNote: .../FBTEST4/platforms/android/src/com/plugin/gcm/PushPlugin.java uses or overrides a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
:preDexRelease
:dexRelease
UNEXPECTED TOP-LEVEL EXCEPTION:
com.android.dex.DexException: Multiple dex files define Landroid/support/v4/accessibilityservice/AccessibilityServiceInfoCompat$AccessibilityServiceInfoVersionImpl;
	at com.android.dx.merge.DexMerger.readSortableTypes(DexMerger.java:596)
	at com.android.dx.merge.DexMerger.getSortedTypes(DexMerger.java:554)
	at com.android.dx.merge.DexMerger.mergeClassDefs(DexMerger.java:535)
	at com.android.dx.merge.DexMerger.mergeDexes(DexMerger.java:171)
	at com.android.dx.merge.DexMerger.merge(DexMerger.java:189)
	at com.android.dx.command.dexer.Main.mergeLibraryDexBuffers(Main.java:454)
	at com.android.dx.command.dexer.Main.runMonoDex(Main.java:303)
	at com.android.dx.command.dexer.Main.run(Main.java:246)
	at com.android.dx.command.dexer.Main.main(Main.java:215)
	at com.android.dx.command.Main.main(Main.java:106)
 FAILED
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':dexRelease'.
> com.android.ide.common.internal.LoggedErrorException: Failed to run command:
  	/Developer/android-sdk-linux/build-tools/22.0.1/dx --dex --output .../FBTEST4/platforms/android/build/intermediates/dex/release --input-list=.../FBTEST4/platforms/android/build/intermediates/tmp/dex/release/inputList.txt
  Error Code:
  	2
  Output:
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
Total time: 34.638 secs
.../FBTEST4/platforms/android/cordova/node_modules/q/q.js:126
                    throw e;
Error code 1 for command: .../FBTEST4/platforms/android/gradlew with args: cdvBuildRelease,-b,.../FBTEST4/platforms/android/build.gradle,-Dorg.gradle.daemon=true
Command finished with error code 8: .../FBTEST4/platforms/android/cordova/build --release
ERROR building one of the platforms: Error: .../FBTEST4/platforms/android/cordova/build: Command failed with exit code 8
    at ChildProcess.whenDone (/Developer/cordova/5.1.1/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:134:23)
    at ChildProcess.EventEmitter.emit (events.js:98:17)
    at maybeClose (child_process.js:743:16)
    at Process.ChildProcess._handle.onexit (child_process.js:810:5)
John_H_Intel2
Are you using 3rd party plugins? Not all plugins are compatible with 5.1.1. It is up to the author of the plugin to update them to be compatible. I would say stick to 4.1.2, or find a 5.1.1 compatible plugin that does what you are looking for.
David_B_12
Thanks John,
Yes it would appear that the push plugin I was using https://github.com/phonegap-build/PushPlugin has now been dumped in favour of https://github.com/phonegap/phonegap-plugin-push for some reason.
