- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
For some reason, probably a change i made cause my project build to fail for android\crosswalk.
The build log contains no error:
- Building a Cordova 4.1.2 application.
- The application name is "MenuWays"
- The package name is "com.softbraintech.menuways"
- Plugin "org.apache.cordova.splashscreen" (0.3.5) installed.
- Plugin "org.apache.cordova.statusbar" (0.1.9) installed.
- Plugin "org.apache.cordova.geolocation" (0.3.11) installed.
- Plugin "org.apache.cordova.network-information" (0.2.14) installed.
- Plugin "uk.co.whiteoctober.cordova.appversion" (0.1.7) installed.
- Plugin "org.apache.cordova.dialogs" (0.2.11) installed.
- Plugin "org.apache.cordova.globalization" (0.2.7) installed.
- Plugin "org.pushandplay.cordova.apprate" (1.1.7) installed.
- Plugin "de.appplant.cordova.plugin.badge" (0.7.0) installed.
- Plugin "org.apache.cordova.inappbrowser" (0.5.4) installed.
- Plugin "com.aquto.cordova.AppleAdvertising" (0.0.1) installed.
- Plugin "nl.x-services.plugins.toast" (2.1.1) installed.
- Plugin "de.appplant.cordova.plugin.email-composer" (0.8.3dev) installed.
- Plugin "nl.x-services.plugins.socialsharing" (4.3.19) installed.
- Plugin "com.phonegap.plugins.barcodescanner" (2.2.0) installed.
- Plugin "org.apache.cordova.file" (1.3.2) installed.
- Plugin "org.apache.cordova.device" (0.2.13) installed.
- Plugin "org.apache.cordova.file-transfer" (0.4.8) installed.
Is there a way to see the log file\error message ?
The build for iOS is ok.
We planned to upload to google play next week and we are unable to build for android anymore.
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I found that the below two plugin are causing the build to fail (they worked well last time i build for android)
https://github.com/phonegap-build/PushPlugin.git
https://github.com/danwilson/google-analytics-plugin.git
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Did you check to see if the author of the plugin pushed changes to each of the plugins?
If the author pushed changes that we do not yet support, you will need to specify the version of the plugin you had previously used.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Dev,
John is right. The push plugin has been updated 5 days ago and the google analytics sometime in July. You should use the older version of the plugin that was previously working for you.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I just confirmed that PushPlugin had a new release recently, https://github.com/phonegap-build/PushPlugin.git released an update to 2.5.0 from 2.4.0 that caused the build to fail. So for now, use version 2.4.0 - https://github.com/phonegap-build/PushPlugin.git#2.4.0
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
There are 2 ways to avoid this issue in the future:
1. Download the plugin locally and include it that way.
2. Determine which version of the plugin you are using and happy with and re-add the plugin specifying the version when its added so that version will always be used even if the author updates it.
