Software Archive
Read-only legacy content
17060 Discussions
Build info
erling_andersen
I am newcomer to cilk but like it.
Now I have been looking for build and linking instructions e.g which libs should I link with.
Now the section
https://software.intel.com/en-us/node/522585
is called
Build, Run and Debug an Intel(R) Cilk(TM) Plus Program
but it has NO info about building.
Hansang_B_Intel
Intel compilers compile and link Cilk Plus programs without any specific compiler flags by default.
This page contains an example showing how to create, build, and run a cilk program starting from a serial program:
https://software.intel.com/en-us/node/522584
erling_andersen
On Windows it worked out of the box.
On Linux I got
/home/eda/mosekprj/dev/bld/vejle/final/default/intelc-15.0.0/dll/libmosek64.so: undefined reference to `__cilkrts_rethrow'
/home/eda/mosekprj/dev/bld/vejle/final/default/intelc-15.0.0/dll/libmosek64.so: undefined reference to `__cilkrts_sync'
/home/eda/mosekprj/dev/bld/vejle/final/default/intelc-15.0.0/dll/libmosek64.so: undefined reference to `__cilkrts_leave_frame'
/home/eda/mosekprj/dev/bld/vejle/final/default/intelc-15.0.0/dll/libmosek64.so: undefined reference to `__cilkrts_get_worker_number'
/home/eda/mosekprj/dev/bld/vejle/final/default/intelc-15.0.0/dll/libmosek64.so: undefined reference to `__cilkrts_bind_thread_1'
/home/eda/mosekprj/dev/bld/vejle/final/default/intelc-15.0.0/dll/libmosek64.so: undefined reference to `__cilkrts_get_tls_worker'
scons: *** [bld/vejle/final/default/intelc-15.0.0/bin/mosek] Error 1
Most likely I have to linking with a cilk library. And that was info I was looking for.
Hansang_B_Intel
You will have to include "-lcilkrts" in this case assuming library search path is properly set up.
FYI, cilk runtime library (libcilkrts.so, libcilkrts.so.5) is located in <compiler installation root>/lib/<arch>/, just in case you have to add library search path for some reason.
Brandon_H_Intel
Hello - I've submitted a documentation request to update the wording on that title too. That section is really on Debugging only. Building and running content is in the less-obviously named "Introduction" section. The report id number is DPD200365882.
