Software Archive
Read-only legacy content
17060 Discussions
Building an APK
re_s_
To build an APK, i go to the BUILD tab, i select android and i click on "start" but the generated file is not an APK.
Can you please check my log and tell me what i need to do to build an APK?
thanks in advance
Build Log
  • Building a Cordova 5.4.1 application.
  • Using platform cordova-android 5.0.0.
  • The application name is "test"
  • The package name is "xdk.intel.blank.ad.template.crosswalk"
  • Preference android-signed set to false. Application will not be signed.
  • Using Crosswalk Embedded 16
  • Plugin "cordova-plugin-legacy-whitelist" (1.1.1) installed.
  • Plugin "cordova-plugin-crosswalk-webview" (1.5.0) installed.
  • App name updated to [test]
  • Updated "minSdkVersion" with "14"
  • Updated "targetSdkVersion" with "23"
  • Updated "installLocation" to "auto"
  • Updated "versionCode" to "1"
  • Updated "versionName" to "0.0.1"
  • Added "debuggable" to "false"
  • The application will not be signed.
Swati_S_Intel1
You haven't signed the application. Pleases check the checkbox "signed" in the build settings and rebuild the app.
re_s_
Thanks for your answer,
I signed it and the downloaded app is something like: test.cordova.crosswalk.20160324556 but what i need is an apk file. Any ideas?
Swati_S_Intel1
It's building for Android with crosswalk runtime. For crosswalk the it builds for arm and x86 architectures, so you get 2 APKs. To build for Android only uncheck the checkbox "Optimize with Crosswalk" at the top of the build settings.
re_s_
optimize with crosswalk was checked.
re_s_
Sorry i thought you said that i must check it.
It works now but my app is not crosswork anymore right?
thanks in advance
Anusha_M_Intel1
Yes, if you did not select the check box 'optimize with crosswalk' then your app is not a crosswalk app.
re_s_
Thanks but how can i make a crosswalk apk file?
Swati_S_Intel1
What you got earlier was a crosswalk build. When you have "optimize for corsswalk" checked and you build for Android, you get the Android with crosswalk build. For crosswalk you get a zip file which contains two APKs, one for Arm architecture and one for x86 architecture.
re_s_
Sorry i havent got a zip but a file without extension. i'll try again later thanks for your helpful answer
Anusha_M_Intel1
If you download the crosswalk build via the UI (in v3088), you should get a zip file. Alternately, you can download the build via email where you will get the following options:
The Cordova Android build for xxx was successful.
You can download your application Zip file with this secure link.
You can download your application ARM file with this secure link.
You can download your application x86 file with this secure link.
You can download your application Log file with this secure link.
The arm and x86 builds will download an apk file.
re_s_
I am sorry i still dont get a zip through Intel XDK.  downloading the Zip through email works well.
Thanks everyone who answered my question.
Swati_S_Intel1
It sounds strange that you are getting zip through email but not through the build interface. Can you please check if your download is complete. Sometimes the file is given temporary name till the download finishes.
