Software Archive
Read-only legacy content
17060 Discussions
Building fails : certificate issue for an iOS app
Michel_K_
My app was successfully published in Google Play store.
It’s not the case for the Apple version, which runs well in my iPad where I transferred it several times, using iTunes.
It wasn’t accepted when I uploaded it to iTunes Connect, using Application Loader. Having changed the certificates, even deleting all for doing the whole process again, the building fails now each time. The issue is about  the identity, which is not found, as you will read in the last part of the log file, reproduced hereafter.
Could you find the reason for that problem ? I would be very grateful to you.
Best regards.
Michel Kohn
CodeSign build/device/MVBD.app
    cd .../MVBD/platforms/ios
    export CODESIGN_ALLOCATE=/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/codesign_allocate
    export PATH="/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin:/Applications/Xcode.app/Contents/Developer/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/local/git/bin:/Developer/android-sdk-macosx/tools:/usr/local/ant/bin"
Signing Identity:     "iPhone Distribution: Michel Kohn (375E3RY9Z4)"
Provisioning Profile: "MVBDProfile"
                      (0e17a658-11b3-4b7f-b05f-424dc2e8dc19)
    /usr/bin/codesign --force --sign B401B82F5A5D2823F539D7469FBB6C06BA73574F --resource-rules=.../MVBD/platforms/ios/build/device/MVBD.app/ResourceRules.plist --entitlements .../MVBD/platforms/ios/build/MVBD.build/Release-iphoneos/MVBD.build/MVBD.app.xcent .../MVBD/platforms/ios/build/device/MVBD.app
B401B82F5A5D2823F539D7469FBB6C06BA73574F: no identity found
Command /usr/bin/codesign failed with exit code 1
** BUILD FAILED **
The following build commands failed:
(1 failure)
Command finished with error code 65: .../MVBD/platforms/ios/cordova/build --release,--device
Error: .../MVBD/platforms/ios/cordova/build: Command failed with exit code 65
    at ChildProcess.whenDone (/Developer/cordova/3.5.0-0.2.7/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:135:23)
    at ChildProcess.EventEmitter.emit (events.js:98:17)
    at maybeClose (child_process.js:753:16)
    at Process.ChildProcess._handle.onexit (child_process
Nadeem_N_
Have u correctly followed steps for ios production certificate because there is 2 type of certificate one for testing one for live for publishing app to store u need to have correct credential, certifcate etc try n build ur app
i.e  legacy hybrid mobile app paltform > ios production > provide production certificate n provising file
Michel_K_
Thank you for your answer !
The issue is seemingly solved as the build succeeded but I couldn't yet check whether the package can be accepted to be published in the App store. It came from the provisionning file which was badly generated. It had the status 'invalid', not shown immediately by the Apple developer center. I generated it again without modifying used data ; this time, it gained the status "active" !
Varun_S_1
Getting this error when building ios app with phonegap-plugin-push" (1.2.3), plugin,  my provisioning profile status is active om apple developer account .
** BUILD FAILED **
	CodeSign build/device/Intel-Push-Test.app
(1 failure)
Error code 65 for command: xcodebuild with args: -xcconfig,.../Intel_Push_Test/platforms/ios/cordova/build-release.xcconfig,-project,Intel-Push-Test.xcodeproj,ARCHS=armv7 armv7s arm64,-target,Intel-Push-Test,-configuration,Release,-sdk,iphoneos,build,VALID_ARCHS=armv7 armv7s arm64,CONFIGURATION_BUILD_DIR=.../Intel_Push_Test/platforms/ios/build/device,SHARED_PRECOMPS_DIR=.../Intel_Push_Test/platforms/ios/build/sharedpch
Command finished with error code 2: .../Intel_Push_Test/platforms/ios/cordova/build --release,--device
ERROR building one of the platforms: Error: .../Intel_Push_Test/platforms/ios/cordova/build: Command failed with exit code 2
You may not have the required environment or OS to build this project
    at ChildProcess.whenDone (/Developer/cordova/5.1.1/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:134:23)
    at Process.ChildProcess._handle.onexit (child_process.js:820:5)
John_H_Intel2
Does your build work when you do not include the phonegap-plugin-push" (1.2.3) ?
Michel_K_
There is no phonegap plugin in my plugin list.
Due to plugin issues of the current XDK version, I had to go back to a previous version of my app, after having deleted plugins which aren't needed.(see another post).
Christoff_P_
Good Day
I have double checked my provision and certificate files and I still get this error, please help
Generating config.xml from defaults for platform "ios"
Calling plugman.prepare for platform "ios"
Preparing ios project
Processing configuration changes for plugins.
Iterating over installed plugins: []
Writing out cordova_plugins.js...
Wrote out iOS Bundle Identifier to "com.afri.Afritelematics"
Wrote out iOS Bundle Version to "0.0.1"
iOS Product Name has not changed (still "FleetTrack")
************* Processing the main config.xml file (after_prepare)  *****************
App Directory = [.../FleetTrack]
Will process and update the following config files:
    Config.xml = [.../FleetTrack/config.xml]
Namespaces:
    prefix/uri ''/'http://www.w3.org/ns/widgets'
    prefix/uri 'intelxdk'/'http://xdk.intel.com/ns/v1'
Name of the app is [FleetTrack]
Updating full app name to [FleetTrack]
Processing preference permissions
Updating the versionCode
Setting [CFBundleVersion] to 1
Updating the versionName
Setting [CFBundleShortVersionString] to 0.0.1
Processing debuggable
Processing config file values
Saving config.xml to [.../FleetTrack/config.xml]
Saving info.plist to [.../FleetTrack/platforms/ios/FleetTrack/FleetTrack-Info.plist]
************* Completed processing the main config.xml file (after_prepare)  *****************
Running command: .../FleetTrack/platforms/ios/cordova/build --release --device
Build settings from command line:
    ARCHS = armv7 armv7s arm64
    CONFIGURATION_BUILD_DIR = .../FleetTrack/platforms/ios/build/device
    SDKROOT = iphoneos8.0
    SHARED_PRECOMPS_DIR = .../FleetTrack/platforms/ios/build/sharedpch
    VALID_ARCHS = armv7 armv7s arm64
Build settings from configuration file '.../FleetTrack/platforms/ios/cordova/build-release.xcconfig':
    CODE_SIGN_IDENTITY = iPhone Distribution
    IPHONEOS_DEPLOYMENT_TARGET = 5.1.1
    PROVISIONING_PROFILE = b5bd6f76-7a84-4c22-b00f-b5437bbc9be1
=== BUILD TARGET CordovaLib OF PROJECT CordovaLib WITH CONFIGURATION Release ===
Check dependencies
Write auxiliary files
/bin/mkdir -p .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64
write-file .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/Cordova.LinkFileList
write-file .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap
/bin/mkdir -p .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7
write-file .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/Cordova.LinkFileList
write-file .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap
write-file .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap
write-file .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova.hmap
/bin/mkdir -p .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu
write-file .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch.pch.hash-criteria
/bin/mkdir -p .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv
write-file .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch.pch.hash-criteria
/bin/mkdir -p .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege
write-file .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch.pch.hash-criteria
write-file .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap
/bin/mkdir -p .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s
write-file .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/Cordova.LinkFileList
write-file .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-non-framework-target-headers.hmap
CpHeader Classes/NSDictionary+Extensions.h .../FleetTrack/platforms/ios/build/device/include/Cordova/NSDictionary+Extensions.h
    cd .../FleetTrack/platforms/ios/CordovaLib
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/NSDictionary+Extensions.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/NSData+Base64.h .../FleetTrack/platforms/ios/build/device/include/Cordova/NSData+Base64.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/NSData+Base64.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVPluginResult.h .../FleetTrack/platforms/ios/build/device/include/Cordova/CDVPluginResult.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVPluginResult.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVInvokedUrlCommand.h .../FleetTrack/platforms/ios/build/device/include/Cordova/CDVInvokedUrlCommand.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVInvokedUrlCommand.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVPlugin.h .../FleetTrack/platforms/ios/build/device/include/Cordova/CDVPlugin.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVPlugin.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVDebug.h .../FleetTrack/platforms/ios/build/device/include/Cordova/CDVDebug.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVDebug.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/NSMutableArray+QueueAdditions.h .../FleetTrack/platforms/ios/build/device/include/Cordova/NSMutableArray+QueueAdditions.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/NSMutableArray+QueueAdditions.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVWhitelist.h .../FleetTrack/platforms/ios/build/device/include/Cordova/CDVWhitelist.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVWhitelist.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVViewController.h .../FleetTrack/platforms/ios/build/device/include/Cordova/CDVViewController.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVViewController.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVCommandDelegate.h .../FleetTrack/platforms/ios/build/device/include/Cordova/CDVCommandDelegate.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVCommandDelegate.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVURLProtocol.h .../FleetTrack/platforms/ios/build/device/include/Cordova/CDVURLProtocol.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVURLProtocol.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDV.h .../FleetTrack/platforms/ios/build/device/include/Cordova/CDV.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/CDV.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVAvailabilityDeprecated.h .../FleetTrack/platforms/ios/build/device/include/Cordova/CDVAvailabilityDeprecated.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVAvailabilityDeprecated.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVAvailability.h .../FleetTrack/platforms/ios/build/device/include/Cordova/CDVAvailability.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVAvailability.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVLocalStorage.h .../FleetTrack/platforms/ios/build/device/include/Cordova/CDVLocalStorage.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVLocalStorage.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/UIDevice+Extensions.h .../FleetTrack/platforms/ios/build/device/include/Cordova/UIDevice+Extensions.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/UIDevice+Extensions.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/NSArray+Comparisons.h .../FleetTrack/platforms/ios/build/device/include/Cordova/NSArray+Comparisons.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/NSArray+Comparisons.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVCommandQueue.h .../FleetTrack/platforms/ios/build/device/include/Cordova/CDVCommandQueue.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVCommandQueue.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVShared.h .../FleetTrack/platforms/ios/build/device/include/Cordova/CDVShared.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVShared.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVCommandDelegateImpl.h .../FleetTrack/platforms/ios/build/device/include/Cordova/CDVCommandDelegateImpl.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVCommandDelegateImpl.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVScreenOrientationDelegate.h .../FleetTrack/platforms/ios/build/device/include/Cordova/CDVScreenOrientationDelegate.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVScreenOrientationDelegate.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVConfigParser.h .../FleetTrack/platforms/ios/build/device/include/Cordova/CDVConfigParser.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVConfigParser.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVWebViewDelegate.h .../FleetTrack/platforms/ios/build/device/include/Cordova/CDVWebViewDelegate.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVWebViewDelegate.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVJSON.h .../FleetTrack/platforms/ios/build/device/include/Cordova/CDVJSON.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVJSON.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVTimer.h .../FleetTrack/platforms/ios/build/device/include/Cordova/CDVTimer.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVTimer.h .../FleetTrack/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVUserAgentUtil.h .../FleetTrack/platforms/ios/build/device/include/Cordova/CDVUserAgentUtil.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVUserAgentUtil.h .../FleetTrack/platforms/ios/build/device/include/Cordova
ProcessPCH .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch.pch CordovaLib_Prefix.pch normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    export LANG=en_US.US-ASCII
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c-header -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -MD -MT dependencies -MF .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch.d -c .../FleetTrack/platforms/ios/CordovaLib/CordovaLib_Prefix.pch -o .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch.pch --serialize-diagnostics .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch.dia
ProcessPCH .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch.pch CordovaLib_Prefix.pch normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c-header -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -MD -MT dependencies -MF .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch.d -c .../FleetTrack/platforms/ios/CordovaLib/CordovaLib_Prefix.pch -o .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch.pch --serialize-diagnostics .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch.dia
ProcessPCH .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch.pch CordovaLib_Prefix.pch normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c-header -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -MD -MT dependencies -MF .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch.d -c .../FleetTrack/platforms/ios/CordovaLib/CordovaLib_Prefix.pch -o .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch.pch --serialize-diagnostics .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch.dia
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.o Classes/CDVInvokedUrlCommand.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVInvokedUrlCommand.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+Extensions.o Classes/NSDictionary+Extensions.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+Extensions.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+Extensions.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/NSDictionary+Extensions.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+Extensions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSData+Base64.o Classes/NSData+Base64.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSData+Base64.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSData+Base64.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/NSData+Base64.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSData+Base64.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.o Classes/CDVPluginResult.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVPluginResult.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.o Classes/CDVPlugin.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVPlugin.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.o Classes/NSMutableArray+QueueAdditions.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/NSMutableArray+QueueAdditions.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.o Classes/CDVURLProtocol.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVURLProtocol.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.o Classes/CDVWhitelist.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVWhitelist.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.o Classes/CDVViewController.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVViewController.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.o Classes/CDVLocalStorage.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVLocalStorage.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/UIDevice+Extensions.o Classes/UIDevice+Extensions.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/UIDevice+Extensions.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/UIDevice+Extensions.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/UIDevice+Extensions.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/UIDevice+Extensions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSArray+Comparisons.o Classes/NSArray+Comparisons.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    export PATH="/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin:/Applications/Xcode.app/Contents/Developer/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/local/git/bin:/Developer/android-sdk-macosx/tools:/usr/local/ant/bin"
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSArray+Comparisons.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSArray+Comparisons.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/NSArray+Comparisons.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/NSArray+Comparisons.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.o Classes/CDVCommandQueue.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVCommandQueue.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.o Classes/CDVCommandDelegateImpl.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVCommandDelegateImpl.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.o Classes/CDVConfigParser.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    cd .../FleetTrack/platforms/ios/CordovaLib
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVConfigParser.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON.o Classes/CDVJSON.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVJSON.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.o Classes/CDVUserAgentUtil.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVUserAgentUtil.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWebViewDelegate.o Classes/CDVWebViewDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWebViewDelegate.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWebViewDelegate.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVWebViewDelegate.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWebViewDelegate.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.o Classes/CDVTimer.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    export LANG=en_US.US-ASCII
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-gvztdfvjsutmnqaimcuyornnyppu/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVTimer.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSDictionary+Extensions.o Classes/NSDictionary+Extensions.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSDictionary+Extensions.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSDictionary+Extensions.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/NSDictionary+Extensions.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSDictionary+Extensions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVInvokedUrlCommand.o Classes/CDVInvokedUrlCommand.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVInvokedUrlCommand.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVInvokedUrlCommand.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVInvokedUrlCommand.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVInvokedUrlCommand.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSData+Base64.o Classes/NSData+Base64.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSData+Base64.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSData+Base64.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/NSData+Base64.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSData+Base64.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPluginResult.o Classes/CDVPluginResult.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPluginResult.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPluginResult.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVPluginResult.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPluginResult.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPlugin.o Classes/CDVPlugin.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPlugin.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPlugin.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVPlugin.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVPlugin.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSMutableArray+QueueAdditions.o Classes/NSMutableArray+QueueAdditions.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSMutableArray+QueueAdditions.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSMutableArray+QueueAdditions.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/NSMutableArray+QueueAdditions.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSMutableArray+QueueAdditions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWhitelist.o Classes/CDVWhitelist.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWhitelist.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWhitelist.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVWhitelist.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWhitelist.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVURLProtocol.o Classes/CDVURLProtocol.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVURLProtocol.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVURLProtocol.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVURLProtocol.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVURLProtocol.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVViewController.o Classes/CDVViewController.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVViewController.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVViewController.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVViewController.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVViewController.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVLocalStorage.o Classes/CDVLocalStorage.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVLocalStorage.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVLocalStorage.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVLocalStorage.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVLocalStorage.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/UIDevice+Extensions.o Classes/UIDevice+Extensions.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/UIDevice+Extensions.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/UIDevice+Extensions.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/UIDevice+Extensions.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/UIDevice+Extensions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSArray+Comparisons.o Classes/NSArray+Comparisons.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSArray+Comparisons.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSArray+Comparisons.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/NSArray+Comparisons.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/NSArray+Comparisons.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandQueue.o Classes/CDVCommandQueue.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandQueue.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandQueue.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVCommandQueue.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandQueue.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandDelegateImpl.o Classes/CDVCommandDelegateImpl.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    export PATH="/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin:/Applications/Xcode.app/Contents/Developer/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/local/git/bin:/Developer/android-sdk-macosx/tools:/usr/local/ant/bin"
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandDelegateImpl.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandDelegateImpl.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVCommandDelegateImpl.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVCommandDelegateImpl.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVConfigParser.o Classes/CDVConfigParser.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVConfigParser.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVConfigParser.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVConfigParser.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVConfigParser.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVJSON.o Classes/CDVJSON.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVJSON.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVJSON.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVJSON.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVJSON.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVUserAgentUtil.o Classes/CDVUserAgentUtil.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    cd .../FleetTrack/platforms/ios/CordovaLib
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVUserAgentUtil.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVUserAgentUtil.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVUserAgentUtil.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVUserAgentUtil.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWebViewDelegate.o Classes/CDVWebViewDelegate.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWebViewDelegate.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWebViewDelegate.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVWebViewDelegate.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVWebViewDelegate.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVTimer.o Classes/CDVTimer.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-cqhfwcexljbcwfanfucbxpcspvqv/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVTimer.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVTimer.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVTimer.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/CDVTimer.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+Extensions.o Classes/NSDictionary+Extensions.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+Extensions.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+Extensions.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/NSDictionary+Extensions.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+Extensions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.o Classes/CDVInvokedUrlCommand.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    export LANG=en_US.US-ASCII
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVInvokedUrlCommand.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSData+Base64.o Classes/NSData+Base64.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSData+Base64.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSData+Base64.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/NSData+Base64.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSData+Base64.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.o Classes/CDVPluginResult.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVPluginResult.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.o Classes/CDVPlugin.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVPlugin.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.o Classes/CDVURLProtocol.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVURLProtocol.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.o Classes/NSMutableArray+QueueAdditions.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/NSMutableArray+QueueAdditions.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.o Classes/CDVWhitelist.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVWhitelist.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.o Classes/CDVViewController.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVViewController.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.o Classes/CDVLocalStorage.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVLocalStorage.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/UIDevice+Extensions.o Classes/UIDevice+Extensions.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/UIDevice+Extensions.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/UIDevice+Extensions.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/UIDevice+Extensions.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/UIDevice+Extensions.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSArray+Comparisons.o Classes/NSArray+Comparisons.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSArray+Comparisons.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSArray+Comparisons.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/NSArray+Comparisons.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/NSArray+Comparisons.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.o Classes/CDVCommandQueue.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVCommandQueue.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.o Classes/CDVCommandDelegateImpl.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVCommandDelegateImpl.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.o Classes/CDVConfigParser.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVConfigParser.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON.o Classes/CDVJSON.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    export PATH="/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin:/Applications/Xcode.app/Contents/Developer/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/local/git/bin:/Developer/android-sdk-macosx/tools:/usr/local/ant/bin"
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVJSON.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.o Classes/CDVUserAgentUtil.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVUserAgentUtil.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWebViewDelegate.o Classes/CDVWebViewDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWebViewDelegate.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWebViewDelegate.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVWebViewDelegate.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWebViewDelegate.o
CompileC build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.o Classes/CDVTimer.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    cd .../FleetTrack/platforms/ios/CordovaLib
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/include -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/CordovaLib_Prefix-atqxrrleubotjpcovtuzjtijcege/CordovaLib_Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.d --serialize-diagnostics .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.dia -c .../FleetTrack/platforms/ios/CordovaLib/Classes/CDVTimer.m -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.o
Libtool build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/libCordova.a normal armv7
    export IPHONEOS_DEPLOYMENT_TARGET=5.1.1
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/libtool -static -arch_only armv7 -syslibroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -L.../FleetTrack/platforms/ios/build/device -filelist .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/Cordova.LinkFileList -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/libCordova.a
Libtool build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova.a normal arm64
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/libtool -static -arch_only arm64 -syslibroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -L.../FleetTrack/platforms/ios/build/device -filelist .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/Cordova.LinkFileList -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova.a
Libtool build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/libCordova.a normal armv7s
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/libtool -static -arch_only armv7s -syslibroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -L.../FleetTrack/platforms/ios/build/device -filelist .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/Cordova.LinkFileList -o .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/libCordova.a
CreateUniversalBinary .../FleetTrack/platforms/ios/build/device/libCordova.a normal armv7\ armv7s\ arm64
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/libtool -static .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/libCordova.a .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/libCordova.a .../FleetTrack/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova.a -o .../FleetTrack/platforms/ios/build/device/libCordova.a
=== BUILD TARGET FleetTrack OF PROJECT FleetTrack WITH CONFIGURATION Release ===
Check dependencies
Write auxiliary files
/bin/mkdir -p .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build
write-file .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-project-headers.hmap
/bin/mkdir -p .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-bsonziqohvteqienxtabwnqbixdw
write-file .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-bsonziqohvteqienxtabwnqbixdw/FleetTrack-Prefix.pch.pch.hash-criteria
/bin/mkdir -p .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-gdbhvddmdnxxipborfaqoxnwoxbv
write-file .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-gdbhvddmdnxxipborfaqoxnwoxbv/FleetTrack-Prefix.pch.pch.hash-criteria
write-file .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Script-304B58A110DAC018002A0835.sh
chmod 0755 .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Script-304B58A110DAC018002A0835.sh
/bin/mkdir -p .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-dzqpwrzkxwzqvjhdhxbximliwafv
write-file .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-dzqpwrzkxwzqvjhdhxbximliwafv/FleetTrack-Prefix.pch.pch.hash-criteria
write-file .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-all-non-framework-target-headers.hmap
/bin/mkdir -p .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7
write-file .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7/FleetTrack.LinkFileList
/bin/mkdir -p .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7s
write-file .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7s/FleetTrack.LinkFileList
/bin/mkdir -p .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/arm64
write-file .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/arm64/FleetTrack.LinkFileList
write-file .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack.hmap
write-file .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-own-target-headers.hmap
write-file .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-generated-files.hmap
write-file .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-all-target-headers.hmap
Create product structure
/bin/mkdir -p .../FleetTrack/platforms/ios/build/device/FleetTrack.app
CpResource /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk/ResourceRules.plist build/device/FleetTrack.app/ResourceRules.plist
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk/ResourceRules.plist .../FleetTrack/platforms/ios/build/device/FleetTrack.app
PhaseScriptExecution Copy\ www\ directory build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Script-304B58A110DAC018002A0835.sh
    /bin/sh -c .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Script-304B58A110DAC018002A0835.sh
real	0m0.251s
user	0m0.101s
sys	0m0.150s
CopyPNGFile build/device/FleetTrack.app/icon-72.png FleetTrack/Resources/icons/icon-72.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/icons/icon-72.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/icon-72.png
CopyPNGFile build/device/FleetTrack.app/icon.png FleetTrack/Resources/icons/icon.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/icons/icon.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/icon.png
CopyPNGFile build/device/FleetTrack.app/icon-76.png FleetTrack/Resources/icons/icon-76.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/icons/icon-76.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/icon-76.png
CompileXIB FleetTrack/Classes/MainViewController.xib
    export XCODE_DEVELOPER_USR_PATH=/Applications/Xcode.app/Contents/Developer/usr/bin/..
    /Applications/Xcode.app/Contents/Developer/usr/bin/ibtool --target-device iphone --target-device ipad --errors --warnings --notices --module FleetTrack --minimum-deployment-target 5.1.1 --output-partial-info-plist .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/MainViewController-PartialInfo.plist --auto-activate-custom-fonts --output-format human-readable-text --compile .../FleetTrack/platforms/ios/build/device/FleetTrack.app/MainViewController.nib .../FleetTrack/platforms/ios/FleetTrack/Classes/MainViewController.xib
CopyPNGFile build/device/FleetTrack.app/icon-40@2x.png FleetTrack/Resources/icons/icon-40@2x.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/icons/icon-40@2x.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/icon-40@2x.png
CopyPNGFile build/device/FleetTrack.app/icon@2x.png FleetTrack/Resources/icons/icon@2x.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/icons/icon@2x.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/icon@2x.png
CopyPNGFile build/device/FleetTrack.app/Default-736h.png FleetTrack/Resources/splash/Default-736h.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/splash/Default-736h.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/Default-736h.png
CopyPNGFile build/device/FleetTrack.app/icon-50.png FleetTrack/Resources/icons/icon-50.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/icons/icon-50.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/icon-50.png
CopyPNGFile build/device/FleetTrack.app/icon-small.png FleetTrack/Resources/icons/icon-small.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/icons/icon-small.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/icon-small.png
CopyPNGFile build/device/FleetTrack.app/icon-60@2x.png FleetTrack/Resources/icons/icon-60@2x.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/icons/icon-60@2x.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/icon-60@2x.png
CopyPNGFile build/device/FleetTrack.app/Default-Landscape@2x~ipad.png FleetTrack/Resources/splash/Default-Landscape@2x~ipad.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/splash/Default-Landscape@2x~ipad.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/Default-Landscape@2x~ipad.png
CopyPNGFile build/device/FleetTrack.app/Default-Landscape~ipad.png FleetTrack/Resources/splash/Default-Landscape~ipad.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/splash/Default-Landscape~ipad.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/Default-Landscape~ipad.png
CopyPNGFile build/device/FleetTrack.app/icon-small@2x.png FleetTrack/Resources/icons/icon-small@2x.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/icons/icon-small@2x.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/icon-small@2x.png
CopyPNGFile build/device/FleetTrack.app/Default-Portrait@2x~ipad.png FleetTrack/Resources/splash/Default-Portrait@2x~ipad.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/splash/Default-Portrait@2x~ipad.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/Default-Portrait@2x~ipad.png
CopyPNGFile build/device/FleetTrack.app/Default-Portrait~ipad.png FleetTrack/Resources/splash/Default-Portrait~ipad.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/splash/Default-Portrait~ipad.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/Default-Portrait~ipad.png
CopyPNGFile build/device/FleetTrack.app/Default-667h.png FleetTrack/Resources/splash/Default-667h.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/splash/Default-667h.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/Default-667h.png
CopyPNGFile build/device/FleetTrack.app/icon-40.png FleetTrack/Resources/icons/icon-40.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/icons/icon-40.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/icon-40.png
CopyPNGFile build/device/FleetTrack.app/Default@2x~iphone.png FleetTrack/Resources/splash/Default@2x~iphone.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/splash/Default@2x~iphone.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/Default@2x~iphone.png
CopyPNGFile build/device/FleetTrack.app/icon-60.png FleetTrack/Resources/icons/icon-60.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/icons/icon-60.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/icon-60.png
CopyPNGFile build/device/FleetTrack.app/Default~iphone.png FleetTrack/Resources/splash/Default~iphone.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/splash/Default~iphone.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/Default~iphone.png
CopyPNGFile build/device/FleetTrack.app/Default-568h@2x~iphone.png FleetTrack/Resources/splash/Default-568h@2x~iphone.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/splash/Default-568h@2x~iphone.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/Default-568h@2x~iphone.png
CopyPNGFile build/device/FleetTrack.app/Default-Landscape-736h.png FleetTrack/Resources/splash/Default-Landscape-736h.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/splash/Default-Landscape-736h.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/Default-Landscape-736h.png
CopyPNGFile build/device/FleetTrack.app/icon-60@3x.png FleetTrack/Resources/icons/icon-60@3x.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/icons/icon-60@3x.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/icon-60@3x.png
CopyPNGFile build/device/FleetTrack.app/icon-50@2x.png FleetTrack/Resources/icons/icon-50@2x.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/icons/icon-50@2x.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/icon-50@2x.png
CopyPNGFile build/device/FleetTrack.app/icon-76@2x.png FleetTrack/Resources/icons/icon-76@2x.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/icons/icon-76@2x.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/icon-76@2x.png
CopyPNGFile build/device/FleetTrack.app/icon-72@2x.png FleetTrack/Resources/icons/icon-72@2x.png
    /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin/copypng -compress .../FleetTrack/platforms/ios/FleetTrack/Resources/icons/icon-72@2x.png .../FleetTrack/platforms/ios/build/device/FleetTrack.app/icon-72@2x.png
ProcessInfoPlistFile build/device/FleetTrack.app/Info.plist FleetTrack/FleetTrack-Info.plist
    builtin-infoPlistUtility .../FleetTrack/platforms/ios/FleetTrack/FleetTrack-Info.plist -genpkginfo .../FleetTrack/platforms/ios/build/device/FleetTrack.app/PkgInfo -expandbuildsettings -format binary -platform iphoneos -resourcerulesfile .../FleetTrack/platforms/ios/build/device/FleetTrack.app/ResourceRules.plist -additionalcontentfile .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/MainViewController-PartialInfo.plist -o .../FleetTrack/platforms/ios/build/device/FleetTrack.app/Info.plist
ProcessPCH build/sharedpch/FleetTrack-Prefix-bsonziqohvteqienxtabwnqbixdw/FleetTrack-Prefix.pch.pch FleetTrack/FleetTrack-Prefix.pch normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    export LANG=en_US.US-ASCII
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c-header -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-generated-files.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-own-target-headers.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I.../FleetTrack/platforms/ios/build/device/usr/local/lib/include -I.../FleetTrack/platforms/ios/build/UninstalledProducts/include -I.../FleetTrack/platforms/ios/build/device -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -MD -MT dependencies -MF .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-bsonziqohvteqienxtabwnqbixdw/FleetTrack-Prefix.pch.d -c .../FleetTrack/platforms/ios/FleetTrack/FleetTrack-Prefix.pch -o .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-bsonziqohvteqienxtabwnqbixdw/FleetTrack-Prefix.pch.pch --serialize-diagnostics .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-bsonziqohvteqienxtabwnqbixdw/FleetTrack-Prefix.pch.dia
ProcessPCH build/sharedpch/FleetTrack-Prefix-dzqpwrzkxwzqvjhdhxbximliwafv/FleetTrack-Prefix.pch.pch FleetTrack/FleetTrack-Prefix.pch normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c-header -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-generated-files.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-own-target-headers.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I.../FleetTrack/platforms/ios/build/device/usr/local/lib/include -I.../FleetTrack/platforms/ios/build/UninstalledProducts/include -I.../FleetTrack/platforms/ios/build/device -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -MD -MT dependencies -MF .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-dzqpwrzkxwzqvjhdhxbximliwafv/FleetTrack-Prefix.pch.d -c .../FleetTrack/platforms/ios/FleetTrack/FleetTrack-Prefix.pch -o .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-dzqpwrzkxwzqvjhdhxbximliwafv/FleetTrack-Prefix.pch.pch --serialize-diagnostics .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-dzqpwrzkxwzqvjhdhxbximliwafv/FleetTrack-Prefix.pch.dia
ProcessPCH build/sharedpch/FleetTrack-Prefix-gdbhvddmdnxxipborfaqoxnwoxbv/FleetTrack-Prefix.pch.pch FleetTrack/FleetTrack-Prefix.pch normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c-header -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-generated-files.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-own-target-headers.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I.../FleetTrack/platforms/ios/build/device/usr/local/lib/include -I.../FleetTrack/platforms/ios/build/UninstalledProducts/include -I.../FleetTrack/platforms/ios/build/device -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -MD -MT dependencies -MF .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-gdbhvddmdnxxipborfaqoxnwoxbv/FleetTrack-Prefix.pch.d -c .../FleetTrack/platforms/ios/FleetTrack/FleetTrack-Prefix.pch -o .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-gdbhvddmdnxxipborfaqoxnwoxbv/FleetTrack-Prefix.pch.pch --serialize-diagnostics .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-gdbhvddmdnxxipborfaqoxnwoxbv/FleetTrack-Prefix.pch.dia
CompileC build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7/main.o FleetTrack/main.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-generated-files.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-own-target-headers.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I.../FleetTrack/platforms/ios/build/device/usr/local/lib/include -I.../FleetTrack/platforms/ios/build/UninstalledProducts/include -I.../FleetTrack/platforms/ios/build/device -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-dzqpwrzkxwzqvjhdhxbximliwafv/FleetTrack-Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7/main.d --serialize-diagnostics .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7/main.dia -c .../FleetTrack/platforms/ios/FleetTrack/main.m -o .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7/main.o
CompileC build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7/AppDelegate.o FleetTrack/Classes/AppDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-generated-files.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-own-target-headers.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I.../FleetTrack/platforms/ios/build/device/usr/local/lib/include -I.../FleetTrack/platforms/ios/build/UninstalledProducts/include -I.../FleetTrack/platforms/ios/build/device -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-dzqpwrzkxwzqvjhdhxbximliwafv/FleetTrack-Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7/AppDelegate.d --serialize-diagnostics .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7/AppDelegate.dia -c .../FleetTrack/platforms/ios/FleetTrack/Classes/AppDelegate.m -o .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7/AppDelegate.o
CompileC build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7/MainViewController.o FleetTrack/Classes/MainViewController.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-generated-files.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-own-target-headers.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I.../FleetTrack/platforms/ios/build/device/usr/local/lib/include -I.../FleetTrack/platforms/ios/build/UninstalledProducts/include -I.../FleetTrack/platforms/ios/build/device -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources/armv7 -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-dzqpwrzkxwzqvjhdhxbximliwafv/FleetTrack-Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7/MainViewController.d --serialize-diagnostics .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7/MainViewController.dia -c .../FleetTrack/platforms/ios/FleetTrack/Classes/MainViewController.m -o .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7/MainViewController.o
CompileC build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7s/main.o FleetTrack/main.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-generated-files.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-own-target-headers.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I.../FleetTrack/platforms/ios/build/device/usr/local/lib/include -I.../FleetTrack/platforms/ios/build/UninstalledProducts/include -I.../FleetTrack/platforms/ios/build/device -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-bsonziqohvteqienxtabwnqbixdw/FleetTrack-Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7s/main.d --serialize-diagnostics .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7s/main.dia -c .../FleetTrack/platforms/ios/FleetTrack/main.m -o .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7s/main.o
CompileC build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7s/AppDelegate.o FleetTrack/Classes/AppDelegate.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-generated-files.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-own-target-headers.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I.../FleetTrack/platforms/ios/build/device/usr/local/lib/include -I.../FleetTrack/platforms/ios/build/UninstalledProducts/include -I.../FleetTrack/platforms/ios/build/device -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-bsonziqohvteqienxtabwnqbixdw/FleetTrack-Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7s/AppDelegate.d --serialize-diagnostics .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7s/AppDelegate.dia -c .../FleetTrack/platforms/ios/FleetTrack/Classes/AppDelegate.m -o .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7s/AppDelegate.o
CompileC build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/arm64/main.o FleetTrack/main.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-generated-files.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-own-target-headers.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I.../FleetTrack/platforms/ios/build/device/usr/local/lib/include -I.../FleetTrack/platforms/ios/build/UninstalledProducts/include -I.../FleetTrack/platforms/ios/build/device -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-gdbhvddmdnxxipborfaqoxnwoxbv/FleetTrack-Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/arm64/main.d --serialize-diagnostics .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/arm64/main.dia -c .../FleetTrack/platforms/ios/FleetTrack/main.m -o .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/arm64/main.o
CompileC build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/arm64/AppDelegate.o FleetTrack/Classes/AppDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-generated-files.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-own-target-headers.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I.../FleetTrack/platforms/ios/build/device/usr/local/lib/include -I.../FleetTrack/platforms/ios/build/UninstalledProducts/include -I.../FleetTrack/platforms/ios/build/device -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-gdbhvddmdnxxipborfaqoxnwoxbv/FleetTrack-Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/arm64/AppDelegate.d --serialize-diagnostics .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/arm64/AppDelegate.dia -c .../FleetTrack/platforms/ios/FleetTrack/Classes/AppDelegate.m -o .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/arm64/AppDelegate.o
CompileC build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7s/MainViewController.o FleetTrack/Classes/MainViewController.m normal armv7s objective-c com.apple.compilers.llvm.clang.1_0.compiler
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch armv7s -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-generated-files.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-own-target-headers.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I.../FleetTrack/platforms/ios/build/device/usr/local/lib/include -I.../FleetTrack/platforms/ios/build/UninstalledProducts/include -I.../FleetTrack/platforms/ios/build/device -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources/armv7s -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-bsonziqohvteqienxtabwnqbixdw/FleetTrack-Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7s/MainViewController.d --serialize-diagnostics .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7s/MainViewController.dia -c .../FleetTrack/platforms/ios/FleetTrack/Classes/MainViewController.m -o .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7s/MainViewController.o
CompileC build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/arm64/MainViewController.o FleetTrack/Classes/MainViewController.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
    export PATH="/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin:/Applications/Xcode.app/Contents/Developer/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/local/git/bin:/Developer/android-sdk-macosx/tools:/usr/local/ant/bin"
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-receiver-is-weak -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -g -fvisibility=hidden -Wno-sign-conversion -miphoneos-version-min=5.1.1 -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-generated-files.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-own-target-headers.hmap -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-all-target-headers.hmap -iquote .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack-project-headers.hmap -I.../FleetTrack/platforms/ios/build/device/include -I.../FleetTrack/platforms/ios/build/device/usr/local/lib/include -I.../FleetTrack/platforms/ios/build/UninstalledProducts/include -I.../FleetTrack/platforms/ios/build/device -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources/arm64 -I.../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/DerivedSources -F.../FleetTrack/platforms/ios/build/device -include .../FleetTrack/platforms/ios/build/sharedpch/FleetTrack-Prefix-gdbhvddmdnxxipborfaqoxnwoxbv/FleetTrack-Prefix.pch -MMD -MT dependencies -MF .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/arm64/MainViewController.d --serialize-diagnostics .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/arm64/MainViewController.dia -c .../FleetTrack/platforms/ios/FleetTrack/Classes/MainViewController.m -o .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/arm64/MainViewController.o
Ld build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7/FleetTrack normal armv7
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -arch armv7 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -L.../FleetTrack/platforms/ios/build/device -F.../FleetTrack/platforms/ios/build/device -filelist .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7/FleetTrack.LinkFileList -dead_strip -weak_framework CoreFoundation -weak_framework UIKit -weak_framework AVFoundation -weak_framework CoreMedia -weak-lSystem -ObjC -fobjc-arc -fobjc-link-runtime -miphoneos-version-min=5.1.1 -framework AssetsLibrary .../FleetTrack/platforms/ios/build/device/libCordova.a -framework CoreGraphics -framework MobileCoreServices -Xlinker -dependency_info -Xlinker .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7/FleetTrack_dependency_info.dat -o .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7/FleetTrack
Ld build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/arm64/FleetTrack normal arm64
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -arch arm64 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -L.../FleetTrack/platforms/ios/build/device -F.../FleetTrack/platforms/ios/build/device -filelist .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/arm64/FleetTrack.LinkFileList -dead_strip -weak_framework CoreFoundation -weak_framework UIKit -weak_framework AVFoundation -weak_framework CoreMedia -weak-lSystem -ObjC -fobjc-arc -fobjc-link-runtime -miphoneos-version-min=5.1.1 -framework AssetsLibrary .../FleetTrack/platforms/ios/build/device/libCordova.a -framework CoreGraphics -framework MobileCoreServices -Xlinker -dependency_info -Xlinker .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/arm64/FleetTrack_dependency_info.dat -o .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/arm64/FleetTrack
Ld build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7s/FleetTrack normal armv7s
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -arch armv7s -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk -L.../FleetTrack/platforms/ios/build/device -F.../FleetTrack/platforms/ios/build/device -filelist .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7s/FleetTrack.LinkFileList -dead_strip -weak_framework CoreFoundation -weak_framework UIKit -weak_framework AVFoundation -weak_framework CoreMedia -weak-lSystem -ObjC -fobjc-arc -fobjc-link-runtime -miphoneos-version-min=5.1.1 -framework AssetsLibrary .../FleetTrack/platforms/ios/build/device/libCordova.a -framework CoreGraphics -framework MobileCoreServices -Xlinker -dependency_info -Xlinker .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7s/FleetTrack_dependency_info.dat -o .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7s/FleetTrack
CreateUniversalBinary build/device/FleetTrack.app/FleetTrack normal armv7\ armv7s\ arm64
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/lipo -create .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7/FleetTrack .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/armv7s/FleetTrack .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/Objects-normal/arm64/FleetTrack -output .../FleetTrack/platforms/ios/build/device/FleetTrack.app/FleetTrack
GenerateDSYMFile build/device/FleetTrack.app.dSYM build/device/FleetTrack.app/FleetTrack
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/dsymutil .../FleetTrack/platforms/ios/build/device/FleetTrack.app/FleetTrack -o .../FleetTrack/platforms/ios/build/device/FleetTrack.app.dSYM
ProcessProductPackaging /Users/builduser/Library/MobileDevice/Provisioning\ Profiles/FleetTrack\ (1).mobileprovision.144437375475.mobileprovision build/device/FleetTrack.app/embedded.mobileprovision
    builtin-productPackagingUtility /Users/builduser/Library/MobileDevice/Provisioning\ Profiles/FleetTrack\ (1).mobileprovision.144437375475.mobileprovision -o .../FleetTrack/platforms/ios/build/device/FleetTrack.app/embedded.mobileprovision
Touch build/device/FleetTrack.app
    /usr/bin/touch -c .../FleetTrack/platforms/ios/build/device/FleetTrack.app
ProcessProductPackaging /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk/Entitlements.plist build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack.app.xcent
    builtin-productPackagingUtility /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/iPhoneOS8.0.sdk/Entitlements.plist -entitlements -format xml -o .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack.app.xcent
CodeSign build/device/FleetTrack.app
    export CODESIGN_ALLOCATE=/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/codesign_allocate
Signing Identity:     "iPhone Distribution: XXXXXXXXXX LTD (Z2X2Q65645)"
Provisioning Profile: "FleetTrack"
                      (b5bd6f76-7a84-4c22-b00f-b5437bbc9be1)
    /usr/bin/codesign --force --sign 9A7F3E10151E5C3B8B529E2A2024397D9BF6B6A6 --resource-rules=.../FleetTrack/platforms/ios/build/device/FleetTrack.app/ResourceRules.plist --entitlements .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack.app.xcent .../FleetTrack/platforms/ios/build/device/FleetTrack.app
9A7F3E10151E5C3B8B529E2A2024397D9BF6B6A6: no identity found
Command /usr/bin/codesign failed with exit code 1
** BUILD FAILED **
The following build commands failed:
(1 failure)
Command finished with error code 65: .../FleetTrack/platforms/ios/cordova/build --release,--device
Error: .../FleetTrack/platforms/ios/cordova/build: Command failed with exit code 65
    at ChildProcess.whenDone (/Developer/cordova/4.1.2/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:135:23)
    at ChildProcess.EventEmitter.emit (events.js:98:17)
    at maybeClose (child_process.js:753:16)
    at Process.ChildProcess._handle.onexit (child_process.js:820:5)
John_H_Intel2
This means that the provisioning profile does not match the distribution certificate that you uploaded.
In the future, please attach the build log, dont copy/paste it :)
Choukse__Piyush
Hi John, I have configured Automatic manage code signing with xcode 9 and its working for locally if i run with xcode or run with terminal with xcodebuild command in both ways I am able to create IPA file with Automatic code style.
but if I tried to run the same code base from jenkins pipeline or I'll connect this machine with ssh & try in both ways it will give me above error I am stuck with that any suggestion will be helpful
error message what I am getting
 /usr/bin/codesign --force --sign A7F8FCD694D7923A3E57826398C3380E2E5A5446 --entitlements  unknown error -1=ffffffffffffffff
