Software Archive
Read-only legacy content
17060 Discussions
Building phase never ends
Cyprien_L_
Hi there,
I get stuck into the building phase for the new version of the project i'm working on.
blocked-at-building-phase
First time I cancelled the build after 2 hours.
The second time I cancelled the build after about 40 hours (just to be sure it was not a lack of patience).
How can i get info on what to do ? I have no logs because they are given at the end of build.
  • Intelk XDK version 3641
  • Android is the only target platform
  • Project HTML5 + Cordova optimized with Crosswalk
The only significant difference I see between the version that had worked and the new one is the addition of some assets (video and image files).
Is someone able to give a hint ?
magdelaine__anthony
got the same problem multiple times, with a timeout error message.
it happens sometimes, for me i removed some unused images to diminuate the weight of the project, for now it's back to normal.
PaulF_IntelCorp
If you project folder is larger than about 400MB it can cause problems on the builder. Above that size is too large for our build system.
