Software Archive
Read-only legacy content
17060 Discussions
COM Server local variables
Peter_Priestley
I have been using the COM Server Wizard to wrap some legacy code and create a component that will be called from IIS/ASP.
One key to success seems to be getting rid of "global data" and turning it into "object data" in the class derived-type definition. Thus anything in Fortran COMMON, variables in SAVE statements etc., are moved to the derived-type definition.
My question is about local variables defined within the Fortran subroutines. It seems to me that local vars might only work if they are given the AUTOMATIC attribute (i.e. allocated on the stack). Variables with STATIC attribute surely amount to global data and may fight if two instances of the component are running on different threads. Have I got this right? The project generated by the COM Server wizard does not appear to enforce AUTOMATIC allocation in project settings.
Or maybe my understanding of apartment threading is incomplete?
Intel_C_Intel
Hi Peter,
Yes, that is correct.
I'll add this to my list of future work.
Leo
