Software Archive
Read-only legacy content
17060 Discussions
[CRITICAL] memory data corruption with GM965 on Dell machines
7oby
New Contributor II
current workaround (if no bugfix BIOS available):
use intel display driver 7.14.10.1272 (v15.2.6) dated 05/11/2007 or older
bugfix BIOS (yet only released for the following systems):
Dell Inspiron 1420 : Update BIOS to >= A09 (BIOS A09 here)
Dell Inspiron 1520 : Update BIOS to >= A09 (BIOS A09 here)
Dell Inspiron 1525 : Update BIOS to >= A09. Verify VBIOS >= 1566
Dell Inspiron 1720 : Update BIOS to >= A09 (BIOS A09 here)
Dell Latitude D530 : Update BIOS to >= A07 (BIOS A07 here)
Dell Latitude D630 : Update BIOS to >= A12 (BIOS A12 here)
Dell Latitude D830 : Update BIOS to >= A13 (BIOS A13 here)
Dell XPS M1330 : Update BIOS to >= A12 (BIOS A12 here)
Dell Vostro 1400 : Update BIOS to >= A09 (BIOS A09 here)
Dell OptiPlex 330 : Update BIOS to >= A05 (BIOS A05 here)
still waiting for fixes for at least these notebooks:
Dell Vostro 1500
I don't know whether these notebooks are affected as well, nor whether a BIOS update is being prepared:
Dell Vostro 1510, 1710, 1700
Dell Latitude ATG
List of notebooks NOT affected:
Dell Vostro 1310
Bottom Line:
I have sufficient reason to belive in some memory corruption bug with the X3100 drivers v15.8 + v15.7.3. I do not think it affects your hardware, but I have the problem. There is also the chance that my GM965 chip is faulty. In addition there is the chance that my bug is not related to the gfx drivers, but just emerges with those two particular gfx drivers and is caused by some other faulty driver or device.
I filed a bug report at intel, with the outcome that they haven't reproduced anything like that. Since I found people with bugs that sound very similar (see below), I want to raise awareness in this forum and help other people google it (if they encounter the same problem). I will updates this posting if I get more information or by some magic it's not the drivers fault.
My walkaround is to use the slightly outdated 7.14.10.1253 of the GM965 gfx drivers. It does not show up in this version.
Selected Details:
I've got a fancy Dell M1330 notebook with intel X3100 graphics integrated into the GM965 chipset. Dell ships this Core2Duo notebook with 7.14.10.1253 of the graphics driver version runnning Vista Business 32Bit @2GB memory. It runs perfectly except that sometimes it doesn't recognize HDMI attached video beamers and big monitors.
Thus I tried:
7.14.10.1437 (v15.8)
7.14.10.1409 (v15.7.3)
Both fix the external HDMI attached device bugs.
However I encounter a severe bug: Memory corruption!
Unfortunately it occurs very infrequent and my test setup to detect memory curruption in this case requires reading big files from harddrive in a loop and checking their md5sum. In general I have to read ~50 - 1000 GB of Data u ntil I encounter a single md5sum error.
The whole course of isolating this bug and accounting the gfx system is not that interesting here. Let me just mention that I threw all the memory tests (incl. the brand new GM965 supporting MemTest86+ V2.01), changed memory modules, CPU stre testing at every single P-State, Harddrive checking (incl. different drivers such as IASTOR.SYS 7.8.0.1012, 7.0.0.1020, MSAHCI.SYS 6.0.6000.20765). I do not encounter these bugs running ubuntu 7.10 or Mac OS X 10.5.1 on the same hardware reading the same files. It took me every evening the last week and some nights to do a thorough test. The bug seems not to be file/harddrive related - just my testing setup is built this way, since it gives me an easy way to validate some of the main memory content.
I am extremely careful if it comes to making hardware or software responsible for a given bug and try to think of every possible inference.
Certainly while switching back and forth with the drivers above I did not change anything else, after having isolated the bug. At that point I tried to find evidence that I'm not the only person. And I found:
Posting #161 (X3100 on MacBook):
"Our assessment of the error is that a bug in the graphics driver code is causing memory corruption within the data used by WoW under some circumstances, leading to a crash."
http://forums.worldofwarcraft.com/thread.html?topicId=3686740801&sid=1&pageNo=9
This is written by a WoW/Blizzard employee. Well, but it's 3D and it's Mac OS X!
There is code sharing amoung different intel drivers (Linux, Windows, Mac OS X). But the same crash also occured using WINDOWS by means of Boot Camp on the same hardware! posting #182:
"heres my windows crash report on the same macbook"
http://forums.worldofwarcraft.com/thread.html?topicId=3686740801&sid=1&pageNo=10
Regarding 3D: I'm using Aero, but the errors occurs with Aero being enabled and disabled.
7oby
New Contributor II
Bump!
Drivers known to have this bug:
7.15.10.1472 (v15.9) dated 04/25/2008
7.14.10.1461 (v15.8.2) dated 04/01/2008
7.15.10.1451 (v15.9 beta) dated 03/20/2008
7.14.10.1437 (v15.8) dated 02/22/2008
7.14.10.1409 (v15.7.3) dated 01/11/2008
7.14.10.1364 (v15.7) dated 11/12/2007
7.14.10.1322 (v15.6) dated 08/31/2007
7.14.10.1295 (v15.4.4) dated 06/29/2007
7.14.10.1283 (v15.4.3) dated 06/06/2007
7.14.10.1277 (v15.4.2) dated 05/24/2007
Drivers considered bugfree:
7.14.10.1272 (v15.2.6) dated 05/11/2007 Dell Download #1, #2
7.14.10.1268 (v15.4.1) dated 05/03/2007
7.14.10.1255 (v15.4) dated 04/18/2007
7.14.10.1253 (v15.2.4) dated 04/20/2007 Dell Download #1, #2
=> timewindow bug introduced [05/03/2007] - [05/24/2007].
Quickest way to detect suffering from memory corruption http://hcidesign.com/memtest Within seconds or very few minutes you should see whether you suffer from memory corruption.
Changelog of driver revisions:
http://downloadmirror.intel.com/12091/ENG/GFX_Vista32_15.6.0.1322_PV_Intel_relnotes_gfx.htm
Found >16 more Users having same memory corruption issue.
Dell Latitude D630
jodeboeck: http://forum.notebookreview.com/showthread.php?t=225271
sarcago (several) http://www.dellcommunity.com/supportforums/board/message?board.id=insp_general&view=by_date_ascending&message.id=271900#M271900
supermario9999 (2 notebooks) http://www.dellcommunity.com/supportforums/board/message?board.id=insp_general&view=by_date_ascending&message.id=278406#M278406
Dell Latitude D830
colleague of jodeboeck: http://forum.notebookreview.com/showthread.php?t=225271
jenzd http://www.dellcommunity.com/supportforums/board/message?board.id=insp_general&thread.id=269494
MikeAP http://www.dellcommunit y.com/supportforums/board/message?board.id=insp_general&view=by_date_ascending&message.id=274681#M274681
sneakymouse
http://www.dellcommunity.com/supportforums/board/message?board.id=insp_general&view=by_date_ascending&message.id=279734#M279734
Dell XPS M1330
7oby (myself)
Mannerwafferl http://www.xps-forum.de/thread.php?postid=75072#post75072
ghopf http://www.dellcommunity.com/supportforums/board/message?board.id=insp_general&view=by_date_ascending&message.id=278861#M278861
haidu (below)
AnybodyM (below)
Dell Vostro 1400
kubrick http://www.dellcommunity.com/supportforums/board/message?board.id=insp_video&message.id=172813
ghopf http://www.dellcommunity.com/supportforums/board/message?board.id=insp_general&view=by_date_ascending&message.id=278870#M278870
AnybodyM (below)
Potentially more users affected:
Dell M1520 running Windows XP:
http://www.notebookforums.com/thread210181.html
Dell Vostro 1500 running Windows Vista x64:
auster: http://forum.notebookreview.com/showthread.php?p=3236359#post3236359
jenzd
Hi!
Just to report some more people suffering from this problem (with Dell Latitude D630 and D830):
http://www.dellcommunity.com/supportforums/board/message?board.id=insp_general&message.id=269494
This is really annoying.
Best regards, Jens
hellfalcon
Hello here!
I have similar problems on my Acer Extensa 5620z under Windows XP Proffesional.
When playing World of Warcraft or Warcraft III on driver releases 14.33 or 14.33.1 sometimes BSOD appears, which reported about memory corruption.
On previous driver releases (14.32.3, 14.31.1, 14.29.1) I didn't encounter such problems. But enabling fog in NfS Pro Street v. 1.0 causes BSOD on _every_ driver release.
Hopf__Gerald
I believe i'm suffering from the same problem 7oby found.
My System: Dell M1330, Vista Home Premium, 2GB Ram.
Originally detected the problems when downloading and unpacking large RARed Installation files, which were corrupt for no good reason. I can reproduce the problem using Prime95's Torture Test - Mode 3 (Blend), which usually either fails in the first few minutes or will then run continously without problems for hours and days until I abort. It does not fail in Prime95 if I only test a few hundred MB of ram, instead of 1500 (which i usually choose), which makes me wonder if the initial swapping is somehow involved as it fails only in the very beginning, when RAM is still beeing freed for prime95 and taken away from Windows OS tasks.
The DELL Self Test detects no memory problems. Memtest86+ (from uBuntu Boot CD) detects no memory problems. Prime95 in Linux (Ubuntu 8.04) detects no memory problems.
Something is VERY strange here. Intel Drivers 7.14.10.1437 are installed (came automagically from Windows Update i think).
My current theories are:
- defect Ram, even though no standalone memtest can detect it (i'll get new ram tomorrow and try swapping that)
- defect HDD (perhaps HDD's 8MB cache defect?), which corrupts data especially while swapping
- weird driver problem.
This post here along with the link to the german site really make it looks like it's a weird intel driver thing. I will investigate this further this weekend to confirm 7oby's theory of the Intel GFX drivers being the cause.
haidu
I am sure I have the same problem. I have an M1330 3GB RAM X3100 VISTA 32. Unfortunately, I spend two weeks to pin down the problem. I swapped several sticks of memory, several hard disks and tried several storage drivers, but only with 7.14.10.1253 GM965 driver I get stability in Orthos blend. I get exactly the same simptoms, it can run for hours if it passes the first 3 minutes meanwhile the swapping is heavy. I think the problem is related to hard disk because everything started with hard disk data corruption and vista reinstall after automatic windows update of graphic drivers. I think that Dell realized that something is fishy because they withdrawed all the more recent graphic drivers from their support site. Probably the bug is wide spread, but is hard to pin down.
Hopf__Gerald
AnybodyM:
I have carried on my investigations this weekend, and i've come to the following conclusions:
- It's definitely NOT the Ram. I've swapped the Ram from 2x1GB Samsung to 2x2GB OCZ and the problem does still exist
- It's present in both Vista32 and Vista64
- It's not affected by the operational mode of the Intel SATA Controller (Compatibility Mode vs. Native AHCI)
Even though i've not yet changed the harddrive (theory "defect HDD"), i'm 99,95% confident that it's the Intel GM965 graphics driver which is corrupting my data and causing all this trouble. Why? I'm now using the REALLY OLD 7.14.10.1253 which is the latest one available at DELL, and even though I've tried hard I was totally unable to reproduce the bug with those (old) drivers installed.
==> Intel, please fix this ASAP (and perhaps withdraw affected drivers in the meantime) ! Data corruption is no trivial matter!
7oby
New Contributor II
AnybodyM:
Disabling pagefile in Windows should rule out faulty HDD. Memtest won't swap then.
I haven't disabled pagefile yet, since I rouled out fault HDD earlier already. Errors also occur reading data from DVD-Rom (which is a different controller and driver).
AnybodyM:
Just to be precise: Even if the corruption does not occur with these old drivers ever, this just means it doesn't trigger the bug. For example you cannot conclude directly that the HDD or DVD-Rom driver is fine. If one component is faulty there are also always at least two ways to fix it: a) fix faulty component b) workaround in all other components talking to the faulty component to make sure bug is not trigged. Both types of fixes a) and b) are applied frequently and common.
haidu:
I can not confirm this one. Here's v.7.14.10.1409 for Lattitude D630, which is also affected:
http://support.euro.dell.com/support/downloads/download.aspx?c=de&cs=dedhs1&l=de&s=dhs&releaseid=R179345&SystemID=LATITUDE%20D630&servicetag=&os=WLH&osl=GE&deviceid=12618&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=1&libid=6&fileid=244176
Hopf__Gerald
7oby:
I don't know how Vista handles operation without a page file, but in Win2K and WinXP this was absolutely NOT recommendable, the OS totally freaks out without page file :-)
7oby:
So many faulty HDDs aren't that likely. But it could have been an incompatibility - perhaps Dell is always using similar drives. Both Dells in which i've so far been able to reproduce this bug (XPS M1330 + Vostro 1400) had a "WD1200BEVS-75UST0" Drive, so... just to be sure, i today acquired a Seagate Momentus 5400.2 SATA drive to replace it with something completely different.
Did my 12th reinstall of Vista, this time absolutely barebone, no SP1, only Ethernet Driver, nothing else.
Prime95 worked perfectly fine. Installed the very latest v15.9 drivers from Intel, rebooted, started Prime and who-would-have-guessed-it: Once again a Hardware fault detected shortly after starting Prime95-Blend-1500MB.
So if it's an incompatibility, it's now beyond any hardware I can change for myself.
I've now installed the latest bugfree driver (7.14.10.1272 (v15.2.6) dated 05/11/2007) according to your list on both of those Dell Laptops (M1330+Vostro 1400) and the problem is gone on both. Not really a solution though, because I too will need the HDMI port soon and am dependent on good HDMI behavior.
By the way: Do we have ANY specific report of someone who can reproduce exactly THIS (and not some hard to pinpoint World of Warcraft problem) on a machine that is NOT a Dell ? This seems to be pretty Dell specific from the posts i've read so far ?
7oby
New Contributor II
AnybodyM:
As I said earlier: Disabling the pagefile is to rule out any swapping (and in general all harddisc i/o) related issues. Memtest doesn't involve hard disc i/o at all - except swapping, which is outside of the control of Memtest. Thus disabling swapfile. However other tests with the CD-Rom revealed to me that the hard disc or SATA controller is not the source of the problems (still they might trigger errors e.g. due to high interrupt traffic).
AnybodyM:
Mine is different already: FUJITSU MHY2120BH.
I did much more to verify it's not hard disc related: E.g. I read linux driver source code to find those hard disc drives with NCQ defects.
AnybodyM:
I would like to know if somebody got his mainboard replaced by dell and the bug vanished! I'd also like to know if there's somebody (one!) with one of the affected notebooks: Dell XPS 1330, Latitude 630, 830, Vostro 1400 etc. and does not suffer from this bug.
AnybodyM:
I'm using HDMI on different monitors and video beamers. If you get to the point that the external monitor disappears in Windows and you can't select this output device, those two things help:
a) disable pivot services in Windows and/or driver
b) In case you still have problems: Boot by forcing booting splash screens to external monitor (Fn + F8).
AnybodyM:
I did google like an hour for Lenovo, HP devices containing GM965 chipset, but did not find any error reports yet.
haidu
7oby:
haidu:
I have an M1330 and I am positive that newer intel gma drivers were posted on Dell site (for M1330) and they are
now erased. I even found links to erased files on their site. As related to D630 it may happen that D630 is far less popular than M1330 and they did not had enough complaints. One more argument is that the info for the D630 driver specifies M1330 although one can not find it under the M1330 downloads.
I have swapped the Fujitsu 120 GB hdd with a 320 WD and I had the same error so hdd is definitely not the problem (at least in my case).
levicki
Valued Contributor I
Everyone, do you have the latest BIOS update in your laptop?
If the answer to the above question is "yes", I would stronly suggest you to return the laptop and ask for a working replacement.
7oby
New Contributor II
IgorLevicki:
I tried various BIOS updates for my XPS M1330 up to and including A10 released 05/06/2008.
IgorLevicki:
At least there is a workaround (see above: installing old driver). I'd be curious if such a "working" replacement exists. I have not yet found anybody suffering NOT from this bug with this hardware (still that doesn't mean such person does not exist; maybe this guy). Please somebody raise his hand, to whom this doesn't apply!
Finally got past 1st, 2nd level support. Dell is investigating this issue. If they can reproduce it and fix it in software, they save a tremendous amount of money for swapping hardware components (e.g. motherboards) meaninglessly. Most people will only discover BSOD, DVD burning and verification errors, CRC checksum unpacking errors and hardly suspect the gfx driver for it.
levicki
I have a Dell Inspiron 1525 and Windows XP SP2 with latest gfx driver from Intel's website and ICH8M in AHCI mode with MSM 7.8. I do not have memory corruption or crashes. I even played Starwars: Battlefront for extended periods of time without any issues.
I am suspecting a hardware problem (perhaps a batch of partially defective or failing chips?) and I personally wouldn't settle for anything less than a pre-tested replacement laptop.
7oby
New Contributor II
IgorLevicki:
Unfortunately this bug is currently Windows Vista only related. Still thanks and maybe once you switched to Vista this thread turns out useful for you.
IgorLevicki:
You are exploring every possible source for the fault. That's nice. I had the same thought in this thread. Unfortunately the spread of manufactoring time of bug affected notebooks is quite big 07/2007 - 03/2008 which makes the theory of a faulty GM965 batch quiet unlikely.
Besides that people got mainboards holding the GM965 replaced (click or another one) and memory and hard drives exchanged (click). And ... nothing helped.
bikerfoo
What version of Prime95 is being used? I am currently investigating this issue using version 25.5. I will keep you posted on progress.
levicki
What if the bug is due to Vista itself then? I had some stability issues with Vista x64 on my desktop computer when I knew that all components work fine (they were tested/replaced). That is actually the reason why I am not running Vista nor I intend to.
bikerfoo
Couple of additional questions.
1. Does the issue occur in AERO Basic?
2. Does the issue occur with 1GB memory?
3 What are the DVMT setting in BIOS?
7oby
New Contributor II
IgorLevicki:
Microsoft Windows XP and Windows Vista are both incredible stable operating systems. It is well known that most instability issues are related to driver issues.
In 2007 all online reported Vista crashes reported to Microsoft have their source in components of the following vendors:
nVidia 28.81%
Microsoft 17,97%
Unknown 17,07%
AMD-ATI 9,30%
Intel 9,83%
source p.47 in this document or see here.
There is no such thing as an unstable Vista. This is well known also to Microsoft and they develop certification programs for drivers and extremely powerful tools to detect errors in drivers as soon as possible:
http://www.microsoft.com/whdc/devtools/tools/SDV.mspx
Therefore Vista itself is not the cause.
bikerfoo:
Only AnybodyM used Prime95 to detect this kind of error. I trust him that the version he used is Vista compatible. But it doesn't actually matter, since other methods (memory test within vista and md5 checksuming) also expose this bug.
Please use Memtest 3.6 which is Vista compatible and detects errors within a few seconds (less 30 secs):
http://hcidesign.com/memtest/
bikerfoo:
I do have the M1330 using Vista Business 32 Bit and here the bug occurs regardless whether Aero is enabled or disabled.
bikerfoo:
On my M1330 the error also occurs with just one memory module of 1GB installed - however maybe less frequent.
On D830 there is one report by MikeAP that his error disappears with just one module installed (click).
bikerfoo:
Dell BIOS neither displays nor allows to change DVMT. Dell BIOS only displays the size of the linear framebuffer, which is mandatory since VESA 2.0 and is of 8MB size. Actually the allocation of DVMT is under the control of the operating system:
"The amount of video memory allocated depends upon the amount requested by the operating system."
http://www.intel.com/support/graphics/sb/CS-010488.htm
Using the older working drivers I can query from the intel tool:
Minimum Graphics Memory: 8 MB
Maximum Graphics Memory: 358 MB
Graphics Memory in Use: 177 MB
The actual used memory (here 177MB) changes during operation. I see 165 - 177MB within a single session. Those values do not seem to be different when installed one of the "bad" drivers above.
However DVMT is also something that came to my mind: Just consider what happens if the driver dynamically reduces the video memory and forgets to alter the Page Attribute Table / MTRR processor registers to switch from WriteCombining Caching strategy as used by framebuffers to WriteBack/WriteThrough. Strong ordering of read/write requests is no longer given => memory corruption.
levicki
XP is stable, that I give you but Vista... no way except perhaps 32-bit version but even there I would think twice before trusting it with my data. Driver model has changed, DRM has been implanted everywhere such a deadly combination of changes is bound to start cracking at seams.
As for that "reliability study" it is a joke. It looks like NVIDIA has the most crashes but those account for video, disk, network, and audio drivers. How do we know the exact percentages? And what is "unknown"?!? Isn't driver signing mandatory? If Microsoft doesn't know whose drivers caused the crash then how can we continue to trust their WHQL certification program? And what about those crashes where Microsoft is to blame (for example kernel bug) and vendor's driver gets caught redhanded?
As for your issue, get some program to dump PCI address space (actual configuration) of GMCH. Make dumps with working and with non-working drivers and compare. Perhaps you catch something.
Also check if the non-working driver is sharing an IRQ and whether it has the same address space listed in device manager as the older one.
Another thing to do is to note the GMCH revision (using Everest) and your CPU stepping and microcode update version.
Hopf__Gerald
Yes. On both my M1330 as well as the Vostro 1400.
There quite likely may not be any working replacements.
I used 25.6, but 25.5 is fine. Just don't use the very old version from www.mersenne.org. Latest versions are available on the ftp://www.mersenne.org/gimps
How to use Prime95 in Vista: Select Torture Test, Select "Blend" Test. Select "Custom" Test. Reduce memory size from 1750 to 1500MB.
(testing 1750MB is too much for Vista, since vista needs more on its own)
You might want to try the "memtest" that 7oby linked to, though. I only tried it once, but it really detected the problem faster than Prime (which needs ~2-3 minutes usually to fail)
I've got Vista working perfectly on a number of machines. Vista has no inherent stability issues.
Never tried that, but it does occur with 4GB memory.
(I used 2x Prime95 each running one Blend Torture thread with 1500MB)
Please refrain from unneccessary Microsoft Bashing. Vista may not be the greatest Invention since sliced bread, but there's nothing inherently unstable about it. I'm using 64bit Vista on my main Desktop PC and i have ZERO data corruption and had ZERO bluescreens in the last months even though its heavily used.
(Well at least since nVidia fixed their drivers, those first few months really weren't great - The report 7oby linked to correctly identifies the initial driver woes that plagued some manufactureres the first half year - but that time has long passed)
Another thing to do is to note the GMCH revision, your CPU stepping and microcode update version.
That would be very interesting to compare once we find a laptop which does NOT exhibit this problem :-)
Perhaps the latest steppings of the GPU core introduced a flaw that was not present from the beginning?
Not very likely though, as hardware bugs tend to get eliminated with new revisions and not introduced...
