Software Archive
Read-only legacy content
17060 Discussions
Can I use Virtual Machine as License Server?
Ning_B_
Can I use Virtual Machine(VMware ESXi ) as License Server for below softwares? Does VM have limitatins to be license server for these applications?
Intel C++ composer XE 2013 for windows
Intel C++ complier
Intel Parallel Buildig Blocks
Intel Integrated Performance primitives 7.1
Intel Math Kernel Library 11.0
Igor_V_Intel
We do not test the Intel License Manager on Virtual Machines and we can't garantee the operation on such enviroments. However, in accordance with a feedback from customers and from my own expierience there is no fundamental restriction in running the Intel License Manager on a Virtual Machine. Note that it doesn't depepnd on the product. If it works - it works for all products, e.g. compiler, VTune Amplifier, etc.
If you encounter problems, send a detailled error report (preferable via Intel Premier Support https://premier.intel.com, product: Download, Licensing and Registration).
Ning_B_
Thanks, we will try to use VM as license server.
