Software Archive
Read-only legacy content
17060 Discussions
Can not get raw depth data
Hui_L_3
I tired to get raw depth data by calling function AcquireAccess(ACCESS_READ, PIXEL_FORMAT_DEPTH_RAW, &data);
But it always failed. If I use PIXEL_FORMAT_DEPTH or  PIXEL_FORMAT_DEPTH_F32, then data.type is correct but the data values remain the same, which means floating point data is value is the same with the depth ones.
Anybody know what is the reason ? I am using R200.
Thanks!
Xusheng_L_Intel
Please provide the part how you enable the stream or whole codes so I can help you find the issue. Thanks!
Hui_L_3
Hi David,
Here are the codes, at the line 21:
#include <Windows.h>
#include <assert.h>
#include <iomanip>
#include <iostream>
#include <string>
#include <opencv2/opencv.hpp>
#include "pxcsensemanager.h"
#include "pxcmetadata.h"
#include "util_cmdline.h"
#include "util_render.h"
#include <conio.h>
static void
cvtPXCImageToMat(PXCImage *inImg, cv::Mat *outImg, PXCImage::PixelFormat format) {
	int cvDataType;
	int cvDataWidth;
	PXCImage::ImageData data;
	/* The function either failed or gives wrong format of data !!!!
	inImg->AcquireAccess(PXCImage::Access::ACCESS_READ, format, &data);
	PXCImage::ImageInfo imgInfo = inImg->QueryInfo();
	std::cout << "The required format is: " << format << ", \n the actual format is: " << data.format << "\n";
	switch (data.format) {
	case PXCImage::PIXEL_FORMAT_DEPTH:
	case PXCImage::PIXEL_FORMAT_DEPTH_RAW:
		cvDataType = CV_16U;
		cvDataWidth = 2;
		break;
	case PXCImage::PIXEL_FORMAT_DEPTH_F32:
		cvDataType = CV_32F;
		cvDataWidth = 4;
		break;
	assert(data.planes[1] == NULL);
	assert(data.pitches[0] % cvDataWidth == 0);
	outImg->create(imgInfo.height, data.pitches[0] / cvDataWidth, cvDataType);
	memcpy(outImg->data, data.planes[0], imgInfo.height*imgInfo.width*cvDataWidth*sizeof(pxcBYTE));
	inImg->ReleaseAccess(&data);
#define SAFE_RELEASE(pt) ((pt)->Release())
static void
recording() {
	PXCSenseManager *pm = PXCSenseManager::CreateInstance();
	pm->EnableStream(PXCCapture::STREAM_TYPE_DEPTH, 320, 240, 30.f);
	pm->Init();
	UtilRender *renderD = new UtilRender(L"Depth");
	cv::Mat depth;
	while (1) {
		if (pm->AcquireFrame(true) < PXC_STATUS_NO_ERROR) break;
		const PXCCapture::Sample *sample = pm->QuerySample();
		if (sample) {
			if (sample->depth) {
				cvtPXCImageToMat(sample->depth, &depth, PXCImage::PIXEL_FORMAT_DEPTH_RAW);
				renderD->RenderFrame(sample->depth);
			if (27 == cvWaitKey(10)) break;
		pm->ReleaseFrame();
	delete renderD;
	SAFE_RELEASE(pm);
int
main(int argc, char *argv[]) {
	recording();
	return 0;
In my machine if I changed the format to DEPTH_RAW it will fail, if I changed it to DEPTH_F32, the pixel values are the same with the DEPTH ones. Which is useless for me. If you could identify the reason, that's will be helpful !
Thanks!
Hui_L_3
No one could help ?
Yiannis_C_
I just subscribed to the thread / I had a similar issue in C# and it ended up to be a wrong frame release for me. (data was not refreshing as they should).
I will look into the code pasted in the coming days and see if i can come up with any valuable input :)
