Software Archive
Read-only legacy content
17060 Discussions
Can not get the camera to load
Chris_C_4
I received the camera today and have installed the SDK and updated the firmware. When I run any of the examples the camera light comes on then immediately turns off.
I am running on USB 3 and the spec of the machine I am using is:
Windows 8
Intel i7-4900MQ CPU @ 2.80GHZ
RAM: 16 GB
Type: 64 bit
NVidia GeForce GTX
germ13
Hello.
Might sound like a dumb suggestion, but have you tried restarting machine?
Another suggestion is to see if it works with the Intel Capture Viewer application at all.
See if you are getting any messages/Errors in your event viewer Windows-X -> Event Viewer ->Windows Logs -> Applications when camera tries to turn on.
Are you running Windows 8 or 8.1? That might be an issue.
Good luck.
MartyG
Yeah, as Germ said, RealSense needs Windows 8.1 in the new Gold version of the SDK.
Also, the camera needs to be plugged directly into a USB 3.0 port on your PC and not in a USB hub.
Chris_C_4
I am running 8.1 and plugged directly into USB 3.0
Capture viewer I get the following:
Color stream: works
Depth Stream: Was Stopped with code [-202]. ERROR: Device failed due to unplug or unavailability. (the green light goes on then turns off)
MartyG
Sorry if this sounds like a silly question Chris, but do you have another USB 3.0 port on your computer that you can plug the camera into?  I find with some USB devices that they will work fine in one port but not in another, and will experience the same kind of power-light shut off that you are having with the camera.
There does not seem to be a good reason why this should happen - some devices just seem to like some USB ports more than others!
Khyati_Ninad_M_
Hi Team,
Any solutions to this issue? I am facing the same problem with my machine and camera.
Kind Regards
Khyati
T_RUTH__P_
Facing the same problems here
The camera is installed everything is installed the camera light also glows but I get a message that the camera is not detected.
The camera is displayed in the hidden devices connected to the computer but when opened either directly or through the capture viewer it doesnot show. Only my inbuilt webcam which is 2d is getting displayed.
The voice recognition is not working
It shows an error failed to load or something else.
I also got my camera late How am I expected to submit my demo within the time also the Intel people are yet to allow any late submissions. I ally donot know what to do
Anyone has their problem solved. I am also facing the problems similar to the posted ones her
Any suggetsions
THANKS
RUTH
