Software Archive
Read-only legacy content
17061 Discussions
Can realsense sdk and dcm work on win10IoT?
Alex_X_
Recently I found the win10IoT version avaliable for Minnow board Max.https://github.com/ms-iot/content
But it declare it is a 32-bit tailored win10.
Have anyone tried realsense sdk on Minnow board Max? Did it work?
samontab
Valued Contributor II
Well, the minnowboard max actually supports Windows 8.1 and the hardware is 64bits, so there is a big probability that it will work.
Win10IoT is more geared towards low powered devices, such as the raspberry pi 2, which can't run the full OS.
samontab
Alex_X_
Thank you for your advice.
I also have a board with NVIDIA 4-Plus-1 (4-Plus-1™) ARM® Cortex-A15 processer,can it possiblely run realsense?
I have tried it with librealsense but failed, because librealsense can run in non-x86 processor.
Have you succeed in using realsenes on Jetson TX1? Thank you.
