Software Archive
Read-only legacy content
Can't disable ECC via micsmc command
Chao_M_
Hi all,
I failed to disable ECC by "micsmc --ecc disable", the output is:
Information: disabling ECC on devices: mic0...
Information: 1 of 1 complete
Status: mic0: error: cannot set ECC mode: device is not in 'ready' state
I checked the status of the MIC card:
mic0: online (mode: linux image: /usr/share/mpss/boot/bzImage-knightscorner)
Did I do something wrong? Any suggestion how to solve it?
Thank you,
Chao
Leonardo_B_Intel
Hello Chao,
Glad to hear it worked for you.
For additional information, you may want to take a look at the MPSS documentation. Most likely the MPSS_Users_Guide.pdf from your installation. The section “State SYSFS Entries” should describe all the possible states. Here's what I read for my version:
ready: card is ready for a boot command
booting: card is currently booting
no response: card is not responding
boot failed: card failed to boot
online: card is currently booted
shutdown: card is currently shutting down
lost: booted card is not responding
resetting: card is processing soft reset
reset failed: card cannot be reset - non recoverable
I am not a specialist on MPSS but I think the case here is that an action like enabling/disabling ECC cannot be performed on a “online” state because it requires changes on the memory configuration. This it can be only performed on “ready” state, that is, before the actual boot of the card.
Best,
Leo.
Leonardo_B_Intel
Hi Chao,
Would you mind trying something like:
Check ECC status:
# micsmc --ecc status
Turn off ECC:
# micctrl -r
# micctrl -w
# micsmc  --ecc disable
# service mpss restart
Check ECC status:
Best,
Leo.
Chao_M_
Thanks you, Leo. It works!
Would you mind explain the difference between the status of "ready" and "online", it seems I can't change ECC when MIC card is online.
Thank you,
Chao
Leonardo_B_Intel
Hello Chao,
Best,
Leo.
Chao_M_
Thank you, Leo.
Chao
