Software Archive
Read-only legacy content
17060 Discussions
Can't find steppings
itzik_s_
HI,
We have just bought our first 2 Xeon Phi and I am working on installing them on a  SUSE* Linux* Enterprise Server SLES 11 SP2 kernel 3.0.13-0.27-default. I am having a problem find out what my steepings is. THe steppings ID says 3, is that C0?
# micinfo
MicInfo Utility Log
Created Wed May 29 11:51:02 2013
System Info
HOST OS : Linux
OS Version : 3.0.13-0.27-default
Driver Version : 6720-13
MPSS Version : 2.1.6720-13
Host Physical Memory : 264518 MB
Device No: 0, Device Name: mic0
Version
Flash Version : NotAvailable
SMC Firmware Version : NotAvailable
SMC Boot Loader Version : NotAvailable
uOS Version : NotAvailable
Device Serial Number : NotAvailable
Board
Vendor ID : 0x8086
Device ID : 0x2250
Subsystem ID : 0x2500
Coprocessor Stepping ID : 3
PCIe Width : x16
PCIe Speed : 5 GT/s
PCIe Max payload size : 256 bytes
PCIe Max read req size : 512 bytes
Coprocessor Model : 0x01
Coprocessor Model Ext : 0x00
Coprocessor Type : 0x00
Coprocessor Family : 0x0b
Coprocessor Family Ext : 0x00
Coprocessor Stepping : B1
Board SKU : NotAvailable
ECC Mode : NotAvailable
SMC HW Revision : NotAvailable
Cores
Total No of Active Cores : NotAvailable
Voltage : NotAvailable
Frequency : NotAvailable
Thermal
Fan Speed Control : NotAvailable
Fan RPM : NotAvailable
Fan PWM : NotAvailable
Die Temp : NotAvailable
GDDR
GDDR Vendor : NotAvailable
GDDR Version : NotAvailable
GDDR Density : NotAvailable
GDDR Size : NotAvailable
GDDR Technology : NotAvailable
GDDR Speed : NotAvailable
GDDR Frequency : NotAvailable
GDDR Voltage : NotAvailable
Device No: 1, Device Name: mic1
Version
Board
Vendor ID : 0x8086
Device ID : 0x2250
PCIe Width : x16
PCIe Speed : 5 GT/s
Cores
Thermal
GDDR
Kevin_D_Intel
The coprocessor stepping field appears just a little further down. It is: Coprocessor Stepping : B1
You have two B1 cards, not C0.
I’m not 100% certain about the Coprocessor Stepping ID mapping to the Coprocessor Stepping, but cards I can access reflect the following:
Coprocessor Stepping : Coprocessor Stepping ID
  • B0 : 1
  • B1 : 3
  • C0 : 2
itzik_s_
Thank you, I guess I missed it.
