Software Archive
Read-only legacy content
Cannot Disable/Enable a button
Nick_F_2
New Contributor III
Hi
I have this Javascript:
function salesType(){
    var saleschecked = $('#salesType').prop("checked");
    localStorage.setItem("salesType",true);
    if (saleschecked == true) {
   $("#atbutton").removeAttr("disabled");
        $('#sales').prop('readonly', true);
    else
    $("#atbutton").attr("disabled", "disabled");
    $('#sales').prop('readonly', false);
and this HTML
<div class="ui-checkbox widget uib_w_65 CheckboxMargin CheckboxWidth" data-uib="jquery_mobile/checkbox" data-ver="0">
                        <label>Input Sales
                            <input type="checkbox" onclick="javascript:salesType()" name="salesType" id="salesType" data-mini="true">
                        </label>
                    </div>
                    <div class="table-thing with-label widget uib_w_66 d-margins UpperWidths LabelText InputText" data-uib="jquery_mobile/input" data-ver="0">
                        <label class="narrow-control label-inline" for="sales">Sales</label>
                        <input class="wide-control" type="number" data-mini="true" value="0" name="sales" id="sales">
                    </div>
                    <a class="widget uib_w_67 d-margins" data-uib="jquery_mobile/button" data-ver="0" data-role="button" id="atbutton" name="atbutton" disabled="disabled">Advanced Data</a>
On page load the Advanced Data button should be disabled and when I check the checkbox, the Sales input becomes readonly as required, but the Advanced Data button is always enabled, I cannot swap between disabled and enabled on checkbox click.
Any thoughts please.
Diego_Calp
Valued Contributor I
OK.
XDK creates JQM buttons as link buttons. They don't have methods as enable disable associated.
http://demos.jquerymobile.com/1.2.0/docs/buttons/buttons-methods.html
Link buttons (<a> element) doesn't have a disabled property. You need to use a workaround like this:
http://stackoverflow.com/questions/6438659/how-to-disable-a-link-button-in-jquery-mobile
Diego
Hamilton_Tenório_da_
Try
$('#atbutton').prop('checked', false);
Nick_F_2
New Contributor III
Hi Thanks for your help, but that doesn't work.
Also I am trying to disable a button not check/uncheck a checkbox.
Nick_F_2
New Contributor III
Bump
Diego_Calp
With AF3 this work for me:
$("#atbutton").prop("disabled",true);
Diego
Nick_F_2
New Contributor III
Nope tried that before and tried it again, but the button refuses to change state.
Diego_Calp
Strange, I just tried it again. The button remains unchanged, but not respond to clicks. If I change with the same method to disabled = false, it is working again.
Are you using App Framework 3 or other?
Nick_F_2
New Contributor III
I'm using jQuery Mobile. Its an app I've been working on for a while.
Diego_Calp
OK.
Diego
Nick_F_2
New Contributor III
Thats a very good point, hadn't considered that.
I will take a look at the links you have posted. Many thanks.
