I have troubles making Xeon Phi work on my system:
Main board: SUPERMICRO X8DTG-QF (http://www.supermicro.com/products/motherboard/QPI/5500/X8DTG-QF.cfm)
CPU: Xeon 5660 (Westmere EP)
NVIDIA GTX 580
Installed the 5110P card and using "lspci" I can see this line: Co-processor: Intel Corporation Device 2250 (rev 11)
OK, I thought it worked but I was wrong, using these following commands
micctrl --initdefaults
micctrl -w
micctrl -r
I got the following results:
No MIC cards found in the system
The MIC driver has been determined to be loaded. Use the
'lspci' utility to verify cards are installed.
Using micinfo, I got:
MicInfo Utility Log
Created Mon Jan 14 16:55:55 2013
OS is RHEL 6.3, I checked the advises in this thread http://software.intel.com/en-us/forums/topic/336017 but it still doesn't work. I wonder if anyone has experienced similar things and it would be nice to let me know your solutions.
Thanks and regards,
Tuan
Our guy who monitors the Intel Xeon Phi driver queues had the following thoughts:
"Supermicro does not have any tylersburg/westmere boards that support Phi with a production BIOS (ie. no ‘large BAR’ support). The symptom of which is lspci enumerates card, however host kernel log will print an error about BAR allocation as soon as the mic driver is loaded into kernel space."
Sorry,
Charles
I had a similar problem with our system and updating the BIOS did the job.
