Software Archive
Read-only legacy content
17060 Discussions
Cannot reopen one same project without restarting
Robert_S_3
Hi, I think there is a bug with the removing of a project.
After I remove a project and try to update it (to reopen it), I get the message "The project is already open.". I try to remove the project again but I get "Invalid project".
So, I have to restart Intel XDK in order to reopen my project. Please fix it.
PaulF_IntelCorp
Robert -- which version of the XDK are you using? (see four digit number in upper right of the window).
When you say "remove a project" are you using the (x) button in the upper right corner of the Projects tab?
Not sure what you mean by "to update it (to reopen it)" -- are you making changes to your project outside of the XDK after having "removed" it and then opening the same project using the "open and intel xdk project"? (the green button in the lower left corner of the Projects tab).
