Software Archive
Read-only legacy content
17060 Discussions
Cannot run OnBoard LED Blink example on Galileo Gen 2
Rama_R_
Am new to the Gen 2 and therefore follow the steps for Galilep Gen 2 in :
https://software.intel.com/en-us/iot/library/galileo-getting-started
The firmware is upgraded successfully and the arduino is also installed. The Galileo is also recognised by my Windows computer.
When I run the code in Arduino the upload goes fine but the the onboard LED does not blink.
Can I be guided on what I miss here?
Rama
NagaVenkat_K_Intel
From the screenshot I see that you selected Galileo as board. If you are using Gen 2 board you may need to select Galileo Gen 2. Please download the latest Intel Ardiuno 1.6.0 which should enable all the three options Edison, Galileo and Galileo Gen 2.
