Software Archive
Read-only legacy content
17060 Discussions
Change file type
Arne_B_1
in the Code-Files (Develop Tab), there is an option to change the file
type to Java or C#. This makes me wonder if there is a possibility to
change the programming language for a whole project from JS to Java.
Are there any examples or instructions?
Chris_P_Intel
To what option are you referring?  How does one see it?  Have you installed any Brackets plugins, maybe you are seeing one of those.
As to your question: no, that's not possible. There are no examples or instructions.  If you want to work in Java, consider using Android Studio.
Amrita_C_Intel
the editor supports all the  languages.But you cannot write apps in Java using XDK. You can open Java files if it is the part of plugin. Hope this helps.
