Software Archive
Read-only legacy content
17060 Discussions
Changing resolution when Capture Aligned Color and Depth Samples using the SenseManager Events (Example 15)
Arnd_G_
I cannot find a way to change image / stream resolution when Capture Aligned Color and Depth Samples using the SenseManager Events (Example 15 in the manual).
The streams are enabled by
            dataDesc.deviceInfo.streams = PXCMCapture.StreamType.STREAM_TYPE_COLOR | PXCMCapture.StreamType.STREAM_TYPE_DEPTH;
            sm.EnableStreams(dataDesc);
So I cannot find any space to set the resolution (and frame rate).
I'm thankful for any help.
Best regards
Arnd
