Software Archive
Read-only legacy content
17060 Discussions
Chart.js
Braglin__Fabio
I'm triyng to add a chart to my Android app using Chart.js
At Intel-XDK emulator and in Debug Mode (DebugTab) this works perfectly, but if I try run it using App Preview or if I build the apk I can't see the chart.
<code>
function Skills(){
        document.getElementById("MinhasHabilidades").style.display = 'block';
        document.getElementById("inicio").style.display = 'none';
        var ChartData = {
            labels: ["Ler", "Ouvir", "Escrever", "Falar"],
            datasets: [{
                fillColor: "rgba(0,128,255,0.5)",
                strokeColor: "rgba(220,220,220,0.8)",
                highlightFill: "rgba(220,220,220,0.75)",
                highlightStroke: "rgba(220,220,220,1)",
                data: [9, 13, 4, 12]
        var ctx = document.getElementById("myChart").getContext("2d");
        window.myBar = new Chart(ctx).Radar(ChartData, {responsive: true});
</code>
When I call the "new Chart(ctx)..." the function stop.
Wesley_S_1
Change <script src="js/chart.js"></script> TO <script src="js/Chart.js"></script< and its works in the example project.
Case-sensitive.
Amrita_C_Intel
Are you using any plugins? If yes then which kind? Featured, third party or core. Emulator does not provide you the true behavior. so try installing that app on your device.
Amrita_C_Intel
I would recommend try building for Crosswalk.
Braglin__Fabio
Dear Amrita,
As I said, I already create the apk and have installed in 3 different mobiles (Galaxy Gran Prime, Moto G, Galaxy Gran Duos), same problem happen. Please, refer to the Build Log below:
Build Log:
  • Building a Cordova 4.1.2 application.
  • The application name is "1000in100"
  • The package name is "onethinonehdr.bragot.ad"
  • Plugin "org.apache.cordova.device" (0.2.13) installed.
  • Plugin "org.apache.cordova.splashscreen" (0.3.5) installed.
  • Plugin "com.google.playservices" (19.0.0) installed.
  • Plugin "com.google.admobsdk" (6.12.2) installed.
  • Plugin "com.rjfun.cordova.plugin.admob" (2.1.7) installed.
  • Plugin "com.wordsbaking.cordova.tts" (0.2.1) installed.
  • Plugin "org.apache.cordova.inappbrowser" (0.5.4) installed.
  • Plugin "com.phonegap.plugins.speech" (1.0.0) installed.
  • Plugin "de.appplant.cordova.plugin.local-notification" (0.8.1) installed.
  • App name updated to [1000in100]
  • Updated "minSdkVersion" with "10"
  • Updated "targetSdkVersion" with "19"
  • Updated "installLocation" to "auto"
  • Added "screenOrientation" to "portrait"
  • Updated "versionCode" to "1"
  • Updated "versionName" to "0.0.1"
  • Added "debuggable" to "false"
About the crosswalk, the apk is too big! But I will try and tell you the result.... App Preview is based on crosswalk webview, no?????
Edited...
I have tried the Crosswalk... can't display the chart too...
Also I have created a new project only with Chart.js... only works in emulator... could you create an example????
Amrita_C_Intel
Can you send me .zip file of your project through PM? So that I can have more details and provide you better solution.
Braglin__Fabio
This is an example app!! The issue is the same!
Wesley_S_1
Case-sensitive.
Braglin__Fabio
Thank you Wesley, it works, I didn't think about it before.
