Software Archive
Read-only legacy content
17060 Discussions
Clarification on the Capabilities of Xeon Phi
Joe_C_5
I have purchased 3x Xeon Phi 3120P.
Now I realize they are totally useless without the compiler, which is another hidden cost of 700 USD. Then, what I am wondering is whether I will have the same regret once I purchase the compilers as well. This is my situation:
- I have an application that I have build myself in C++ and that I want to run as a native application on the device. However, the application has many dependencies from other libraries, who are used as such, i.e. the shared libraries are already compiled either for 32-bit or 64-bit x86 architecture. I dont have their source code to recompile them for the MIC. My biggest worry is whether I can port those libraries on the XEON PHI?
Most of this libraries are socket communication interfaces for a database data pull. The database is located on the host, I pull data from the host, process the data, and retrieve back a result to the database. I repeat the same thing in a cycle. They do have plenty of pointers and structs. Please explain to me how can I port that application to the XEON PHI? My application works perfectly with MPI on the CPU, but I need greater level of parallelism, hence I use the PHI. It has more cores than my CPUs. However, I am already dissapointed to hear that you are selling a device without the compilers. What I am worried to hear that there will be limitations on the portability too, only to realize NVIDIA GPU is far better choice. Unless I am mistaking?!
I am looking to hear from you, as soon as possible.
TimP
https://software.intel.com/sites/default/files/650_Intel_R__Xeon_Phi_tm__Cluster_configuration-v081.pdf
is a valuable reference on porting libraries which can be built with the gcc which comes for free with the MPSS.  I don't know whether Intel has a public site where the pre-built libraries referred to there may be downloaded.
Many of those libraries could also be built with the Intel compilers; where they don't provide for cross-compilation, you may find the setup awkward.
More complete gcc support appears to be coming for the future KNL version of Intel(r) Xeon Phi(tm).
Joe_C_5
Tim, are you saying that Intel or gcc cannot cross-compile those already compiled shared libraries?
Joe_C_5
Also, I am not starting with a cluster. Lets say, I want to port the application to one of the Phis. How do I proceed with the porting, with gcc? Can you give me reference? Intel support on this is total crap.
TimP
Yes, you are pretty much dead for porting to KNC if you don't have source code.  KNL will offer some x86_64 instruction set compatibility, at a price in performance.
I don't see how you intended to link against x86 compiled code and run on Nvidia GPU.
