Software Archive
Read-only legacy content
17060 Discussions
Close all but 1 QuickWin window
Intel_C_Intel
I have a QuickWin program in which I would like to implement a "Close All" command--except that I want to leave one window open, unit 10. The other unit numbers are not known, although there's only one in the range 20-29, one in the range 30-39, .... Now, this works
  DO I = 11, 99
    CLOSE(I)
  ENDDO
but I need to deallocate arrays according to what unit is actually closed.
I thought something like the following would be helpful, but GetUnitQQ() always returned -1.
NextUnit = GetUnitQQ(GetWindow(GetHwndQQ(10), GW_HWNDNEXT))
Does anyone know how to fix this up? Otherwise I'm left with restoring and minimizing window unit 10 whenever it gets the focus, and that seems quite clunky!
  INTEGER :: I, nUnit, NextWin
! Close all child windows except LUN=10
  I = FOCUSQQ(10)
  nUnit = NextWin(10)
  DO WHILE(nUnit .NE. 10)
    CALL MY_CLOSE_ROUTINE(nUnit)
    I = INQFOCUSQQ(nUnit)
    IF (nUnit .EQ. 10) nUnit = NextWin(10)
  ENDDO
INTEGER FUNCTION NextWin(RefWin)
  USE DFLIB
  IMPLICIT NONE
  INTEGER, INTENT(IN) :: RefWin
  INTEGER :: I, nWin
  TYPE (QWINFO) :: wc
  wc%type = QWIN$RESTORE
  I = SetWSizeQQ(RefWin,wc)
  wc%type = QWIN$MIN
  I = INQFOCUSQQ(nWin)
  IF (nWin .EQ. RefWin) THEN
  ENDIF
  NextWin = nWin
END FUNCTION NextWin
I appreciate what a helpful forum this is!
Dick
You can use INQUIRE (UNIT=n,OPENED=logicalvar) to see if a unit is open, and then process accordingly.
Steve
Intel_C_Intel
Ah, but of course! Thank you, Steve.
