Software Archive
Read-only legacy content
17060 Discussions
Code Coverage support in Intel(r) Parallel Composer
Moshe_V_Intel
I noticed that Intel Parallel Composer includes a code coverage capability, via menu "Billd" -> "Code Coverage Operations".
I could not find though sufficiant documentation about how to perform code coverage and didn't figure out how to work with it and view results.
help is very much appreciated.
thanks
Moshe_V_Intel
A partial solution may be found in the Intel C++ Compiler, lookup "codecov" in the document
http://software.intel.com/file/6339
Om_S_Intel
The codecov tool is documented in Pallel Composer documentation, topic "code coverage Tool".
. The documentation needs an update.
You need to use compiler option /Qcov-gen compiler option to generate the istrumented binary instead of /Qprof_gen compiler option. The /Qprof_gen and /Qprof_use compiler options are not supported in Pallel Composer.
