Software Archive
Read-only legacy content
17060 Discussions
Code GL not working
Mohd_Fariz_H_
Hi, Im using example code from mapboxgl. I can view just fine in emulator intelxdk but after building apk file , the app display white blank page. Please help
PaulF_IntelCorp
Mohd -- I recommend you look at how the sample named "Blank Cordova Starter App" is structured. It has lots of comments. You must wait until the devicready (combined into app.Ready in that sample) fires before you run any significant code. Also, if you are relying on the network you will need to restructure your app so it does not rely on a network connection. See the other samples.
