Software Archive
Read-only legacy content
17060 Discussions
Common blocks and Visual C ++
Deleted_U_Intel
Ok I've read the Mixed language programming section and tried
porting some legacy code with common blocks and C structures.
No luck. So I tried the examples and still had no luck.
Here is the link error from trying the examples. It looks like your basic name mangling.
What compiler option settings should I look at?
Compiling...
testcommon.cpp
Compiling Fortran...
F: est est1.for
Linking...
testcommon.obj : error LNK2001: unresolved external symbol 'double PI' (?PI@@3NA)
Debug/test1.exe : fatal error LNK1120: 1 unresolved externals
Error executing link.exe.
test1.exe - 2 error(s), 0 warning(s)
Here is the test code.
test1.for
  PROGRAM TEST1
      IMPLICIT NONE
      INTEGER*4 I
      INTEGER*4 J
      REAL*8 PI
      COMMON/ PI /PI
      INTERFACE
         INTEGER*4 FUNCTION TESTCOMMON(N)
         INTEGER*4 N
         END FUNCTION TESTCOMMON
      END INTERFACE
      PI = DATAN(1.0D0)*4.0D0
      WRITE(*,*)' PI IN FORTRAN = ',PI
      J = 5
      I = TESTCOMMON(J)
      WRITE(*,*)' I = ',I
      END
testcommon.h
#ifndef TESTCOMMON_H
#define TESTCOMMON_H
extern double PI;
#endif
testcommon.cpp
#include                 // input output streams header file
#include
#include
#include 'testcommon.h'
extern 'C'{ int __stdcall TESTCOMMON(int*);}
int __stdcall TESTCOMMON(int *n){
  int result_count = 1;
  cout << endl;
  cout << ' n = ' << *n << endl;
  cout << ' PI = ' << PI <<  endl;
  return(result_count);
You're almost there. Add 'C' to the extern declaration of PI in your C++ code.
Steve
